I'm trying to build a system that will remount a USB drive when plugged in.
The USB, when plugged in, is then mapped to something like /dev/sdc1. I then want to unmount, then remount using pmount (in order to get user permissions, so another program can read/access the USB drive). The following commands I have been running manually:
  1. sudo umount /dev/sdc1
  2. pmount /dev/sdc1 some_label
I then have another program that will read the files from /media/some_label.
However, this needs to be done programmatically. I have created the following udev rule:
ACTION=="add", \
ATTRS{idVendor}=="154b", \
ATTRS{idProduct}=="00ed", \
RUN+="/usr/bin/bash /home/some/script/location/script.sh"
I know it's being run because I can change the run command to mkdir and I see the (test) directory is created when I plug in my USB.
However, I'm unsure of how to find the device path (/dev/sdc1) programmatically in a shell script. With that, I'm able to run those 2 commands I listed above.
Any suggestions?
Some Guy
  • 173
Udev:
Pass the environment variable as:
RUN+="/home/some/script/location/script.sh DEVNAME=$env{DEVNAME}"
and in the script script.sh parse the $@ variable for the device name as:
if [[ "$@" =~ (DEVNAME=/dev/sd.?) ]] ; then
__DEVNAME="${BASH_REMATCH[1]}"
__DEVNAME="${__DEVNAME#*=}" ; fi
You should then have device names e.g. /dev/sda in the $__DEVNAME variable.
Bash:
Install jq with:
sudo apt install jq
To find the device partition and mount point:
For partitions:
sudo lsblk -o NAME -J /dev/sda | jq -r '.blockdevices | .[].children | .[] | .name'
For mountpoint:
__TMPFILE="$(mktemp)"
sudo lsblk -p -o NAME,MOUNTPOINT -J /dev/sda | jq -r '.blockdevices | .[].children | .[] | "declare -A __MOUNTS[\(.name)]=\"\(.mountpoint)\""' > "$__TMPFILE"
source $__TMPFILE
echo "Your mount point for sda1 is ${__MOUNTS[sda1]}"
rusty
  • 16,917
