Yesterday I re-installed Ubuntu on my laptop. Today, whilst running npm i for a cloned repo, I got a no space error. Error displayed in terminal window following npm i
It said that there was no space in root. I have dual boot Windows and Ubuntu on a 1TB system. Ubuntu should be allocated about 60GB.
disk allocation of memory
I tried to find a way to remove items from root, but there are two issues here, it's a temporary fix, and I don't want to delete files which I don't know what they do. df -h gives the following:
teminal window of df -h
I am a noob at partitioning hard-drives and data storage. I will be cloning repos and running npm i on the daily. Please help me find a way to set up my system so I don't have issues with storage.
Additional Info: On initial installation of Ubuntu, I created a partition from witin windows and then installed Ubuntu with some custom settings, (I followed a guide). This guide allocated a swap (no idea what it does). In the disk image above file partition 9 i s not mounted, but partition 8 is mounted at root. I dont know what this means, but maybe it helps with diagnosis!
Thank you for reading, I hope you can help :)
peace x
Edit: after further investigation, I can see all of the files present before the re-install are still there on the un-mounted partition. See: Devices & Location shows old files still exist This is NOT what I thought happened when I clicked "Re-install ubuntu". I thought It would wipe the partition and start fresh...
Solved Solved Solved
After a long time of reading other posts I finally saw the light!
Re-installing Ubuntu only used one partition of my hard drive. It left the old files intact. I had to delete the old partition, wiping the old data, then expand the new ubuntu partition to the right, now there is enough space and you can see from df -h that the allocated space for the root is now much larger! :)Increased size from 15GB to 46GB (33%)
Joshua
Re-installing Ubuntu only used one partition of my hard drive. It left the old files intact. I had to delete the old partition (this wiped the old data), then expand the new ubuntu partition to the right, now there is enough space and you can see from df -h that the allocated space for the root is now much larger!
33% is now used
Joshua
