How to find out what is installed in the package.deb via the command line? I'm trying to figure out if some daemon or service was installed along with the package. What command can I use to find out?
You can use dpkg to view a deb file
dpkg --info /path/file.deb
to get general information, and
dpkg --contents /path/file.deb
to get the files (programs, libraries, documents etc) listed:
Edit: You can also view a deb file with emacs
emacs /path/file.deb
and that way get into the different parts of the deb file
Example from ppa:mkusb/unstable which I am developing. The following command
emacs dus_22.0.7-1ubuntu1_all.deb
brings you to a table
Mode User/Group Size Date Filename
rw-r--r-- 0/0 4 2022-06-03 17:03 debian-binary
rw-r--r-- 0/0 1420 2022-06-03 17:03 control.tar.xz
rw-r--r-- 0/0 58968 2022-06-03 17:03 data.tar.xz
You can enter the control tarball to see the same as dpkg --info and enter the data tarball to see the same as dpkg --contents and furthermore very conveniently enter each of the files if they are possible to read (and most of the dus files are bash shellscripts).
Edit 2: Install package from deb file
The command line
sudo dpkg -i package.deb
should install package and make its program(s) available like other programs, if that is what you want.
- 47,684
Rather than look at deb files looking for a program (gpsd in below example), you can run:
apt-file search bin/gpsd
and get the list of packages containing your daemon.
First you would install apt-file
sudo apt-get install apt-file
Then update
sudo apt-file update
Then searches will work, even on non-installed debs.
- 19,049
List what files belong to a package:
dpkg -L packagename
and soon you will want the reverse command too, how to see to which package a file belongs to (if any):
dpkg -S /my/path/somefile
Both commands work only for packages which are already installed.
- 842
- 1
- 8
- 14
