-1
I restarted my Ubuntu Laptop after long time and now I can't start Graphical User Interface anymore. To solve this problem I tried to repair the packages from the recovery system, which said that there is not enough memory available. So I tried to free some memory using the root shell, but after freeing some memory, memory usage doesn't change and the calculation seems to be wrong too.
I have a Partition of 92 GB and only use 88 GB but df still says that I use 100% of the memory and 0 GB are available.
Is there any solution to correct the Memory calculation or is there a reason why it doesn't calculate correct?
Franz
  • 101
Here is what I use to free up space
apt autoclean && apt autoremove && sudo apt --purge autoremove && sudo apt clean all && sudo apt purge $(dpkg -l | awk '/^rc/ { print $2 }')
Also remove any extra kernels
dpkg --list | grep linux-image | awk '{ print $2 }' | sort -V | sed -n '/'`uname -r`'/q;p' | xargs sudo apt-get -y purge; sudo apt-get autoremove -y; sudo update-grub
Caution that the backtick ` has a tendency of not copy pasting correctly.
Czar
  • 610
