Ubuntu 22.04 64-bit LTS
I was surprised to see the new screenshot tool throw up a message that I could paste the screenshot into a file. Why should this be required? My old 18.04 setup could do it out of the box. How do I configure this basic function? I could not find anything in settings.
tagMacher
  • 708
Even if I liked the old gnome-screenshot tool, the new tool even improves.
If you just invoke it, PrtScr, you can still do everything: make screenshots of the entire screen, a window or selection, or record the screen. You do not need to think ahead on whether you want a screenshot to file, or one to the clipboard: the new tool just does both.
Make your screenshot, and find the file in ~/Pictures/Screenshots, or paste it in your application. It is your choice.
If you know what you want to capture, then hit Shift+PrtScr to capture the entire screen, or Alt+PrtScr to capture the active window. Again, no need to think ahead: paste the figure or find the file in ~/Pictures/Screenshots: it is your choice.
So also in 22.04, both functions are available, but the mental overhead - do I want output in clipboard or in a file - has been removed.
vanadium
  • 97,564
The screenshots should automatically be saved into ~/Pictures/Screenshots or the equivalent if you're using a different language. You can directly navigate to the folder from the message you see when taking a screenshot by hovering your mouse over the dialog.
Screenshot of the "Screenshot captured" dialog.
ccbirb
  • 633
