I had some problem. I need to copy about 10 million small files to an external hard drive. I was trying to do the job by several ways, but nothing worked.
First I tried cp command. But after about a million of files were copied, it slowed down badly.
Second I tried to make a tar. But after about 20 hours of work only 5 million files were archived.
Then I tried the rsync command. But the result was the same as with the copy command.
At the end my external drive stopped working at all...
I have a new external hard drive. The problem begin when I was trying to copy fileswith the help of rsync command
After an hour about 1 million files were copied, but then the process stopped I canceled the process and now I cannot open my hard drive The process was canceled by CTRL + C in the terminal. After that I couldn't open the dist and just restarted the PC
If I try to open it, it gives an Error:
Unable to access Transcend. An operation is already pending
If I open the Disks. I can see the Hard Drive there.
Assessment: Disk is Ok
But there is an active Job.
Mounting Filesystem.
Menu for the disc is unavaliable. I cannot format it.
I've already restarted the PC. No changes I've also tried to remove the hard drive and insert it again. But also no changes
How can I fix this problem?
I'm using Ubuntu 20.04. External Hard Drive format is ext4
Finally I have 2 problems.
  1. I still don't know how to copy such amount of files.
  2. My external hard drive stopped working (
Update lsblk:
sde           8:64   0   3,7T  0 disk
└─sde1        8:65   0   3,7T  0 part
df -i command
