Just upgraded from 20.04 to 22.04 (too bad it had to go thru 21.10 and then to 22.04), but after upgrade was completed, after it goes to sleep (close the lid or just inactivity), it wakes up dimmed.
When pressing the bar properties (top right, by the battery sign ), the display brightness slide is in the same place it was left (quite close to 100%), when actual display is about 60-70%. When touching its slider, it goes back to its expected value.
I'm using an i7 ThinkPad.
Appreciate any help
Guy
guyd
  • 987
If you can find a terminal command or script that reliably changes your screen's brightness in hardware, you should be able to make your system automatically change its brightness back to 100% after every wakeup. Here's a really long list of techniques for changing screen brightness from the command line: How to change LCD brightness from command line (or via script)?
Once you find the command that works for you, turn it into a script like this (adapted from https://unix.stackexchange.com/a/404010):
#!/usr/bin/env bash
case $1 in
  post)
    plop your screen brightness fixing command here
esac
Obviously, replace the placeholder accordingly. Then save the script as /usr/lib/systemd/system-sleep/brightnessfix.sh (assuming you don't already have a script named brightnessfix.sh in the /usr/lib/systemd/system-sleep directory), and then run the following sequence of commands to set the permissions properly:
sudo chown root:root /usr/lib/systemd/system-sleep/brightnessfix.sh
sudo chmod 0755 /usr/lib/systemd/system-sleep/brightnessfix.sh
ArrayBolt3
  • 7,292
In this Power settings is a section called Power Saving. In that is an option called Dim Screen, described as (Reduce screen brightness when the device is inactive.)
Disabling that worked for me. It should work for you, and doesn't need any scripting.
kberg
  • 111
