I currently have an OpenVZ VPS system running 10.04LTS, which I need a newer build of PHP 5.3 on. This is because I use PHP-FPM for all the virtual sites it hosts, and the Lucid build doesn't include this feature. I was previously using a PPA provided by the Nginx packaging team but they've recently discontinued it which leaves me with an old, buggy, vulnerable version of PHP.
Are there any PHP 5.3.x PPAs which are still kept up to date? By searching Launchpad I've found several with version 5.3.5 but this is also terribly old, and I've found Brian Mercer's PPA but the description says that will be disappearing soon as he no longer needs to maintain it for himself.
So are there any PPAs which offer up a backported/upstream version of PHP 5.3.x (i.e. 5.3.13 which is current) including the PHP-FPM setup? Cheers!
edit - I should further explain that as this is OpenVZ and the VPS provider don't yet provide a 12.04 template, I can't upgrade to 12.04LTS, at least not yet. So while this might be a long-term option, it's not an answer to my immediate question :)
Jorge Castro
  • 73,717
gac
  • 121
In the end, I found a PHP 5.4 PPA (at ppa:ondrej/php5), and decided to test that with the few webapps I run on that VPS. All seemed well (aside from vBulletin's upgrade system, but I have a workaround for that), so I've skipped the 5.3 series altogether and switched to 5.4. Probably won't be upgrading to 12.04LTS yet, although at least I now know that it's possible, and how to do it :-)
gac
  • 121
Try:
ppa:zulcss/php5.3-lucid
ppa:igb/ppa-lucid-testing
jasmines
  • 11,311
