I am new to programming, currently trying to install git but unable to do so...it showing following output on terminal.
dell@dell-Inspiron-5520:~$ sudo apt install git
[sudo] password for dell:
Reading package lists... Done
Building dependency tree... Done
The following packages were automatically installed and are no longer required:
chromium-codecs-ffmpeg-extra gstreamer1.0-vaapi libgstreamer-plugins-bad1.0-0 libva-wayland2
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
git-man liberror-perl
Suggested packages:
git-daemon-run | git-daemon-sysvinit git-doc git-email git-gui gitk gitweb git-cvs git-mediawiki git-svn
The following NEW packages will be installed:
git git-man liberror-perl
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 26.5 kB/7,727 kB of archives.
After this operation, 29.7 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Ign:1 http://in.archive.ubuntu.com/ubuntu jammy/main amd64 liberror-perl all 0.17029-1
Err:1 http://in.archive.ubuntu.com/ubuntu jammy/main amd64 liberror-perl all 0.17029-1
Could not connect to in.archive.ubuntu.com:80 (43.255.166.254), connection timed out
E: Failed to fetch http://in.archive.ubuntu.com/ubuntu/pool/main/libe/liberror-perl/liberror-perl_0.17029-1_all.deb Could not connect to in.archive.ubuntu.com:80 (43.255.166.254), connection timed out
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
