10
I made a fresh install of Ubuntu 22.04 from a live usb key around start of May, on two different machines. Everything went fine except that the icons on the desktop do not open. More precisely:
Both for files and folders on the desktop (including the home directory icon that 22.04 puts by default), the following methods only make the icon highlighted, but do not open it (whether using the mouse or the touchpad):
  • left double click
  • middle click
  • right click + "Open" in the menu.
Only the following method does work for files on the desktop (but is not available for folders):
  • right click + "Open with..." + select the first application --- or any other in the list, actually.
The following observation might also be of interest:
  • I can launch the Gnome Files manager from the side bar, open my desktop folder in it, and then open anything inside with any usual method, such as double click
  • I can also right click on an icon on the desktop, and select "Show in Files", and then it appears in Files and I can double click on it
  • however, if I right click directly on the Desktop and select "Open Desktop in Files", then nothing happens.
I made the following checks:
  • the permissions of my Desktop folder, and of the folders and files in it, are correct (755 or 644)
  • the default applications are correct (document viewer for pdf files, text editor for txt files, etc.)
  • sudo apt-get install --reinstall ubuntu-desktop
  • wait a few weeks for updates and install them
  • create new users with default configuration.
But the problem is still there. Any ideas that could help? (The only hypothesis that further comes to my mind that I have not investigated yet, is that I installed gnome-tweaks on both machines, so maybe it could interfere somehow.)
EDIT: each time I try and fail opening an icon on the desktop, /var/log/syslog logs errors of this type:
gnome-shell[xxxx]: DING: grep: /proc/sys/fs/binfmt_misc/WSLInterop: No such file or directory
gnome-shell[xxxx]: DING: WSL Interopability is disabled. Please enable it before using WSL.
gnome-shell[xxxx]: DING: #033[31m#033[1m[error] WSL Interoperability is disabled. Please enable it before using WSL.#033(B#033[m
gnome-shell[xxxx]: DING: /usr/bin/wslview: line 216: /mnt/c/Windows/System32/reg.exe: No such file or directory
gnome-shell[xxxx]: DING: /usr/bin/wslview: line 308: [: -ge: unary operator expected
gnome-shell[xxxx]: DING: #033[31m[error]#033(B#033[m This protocol is not supported before version 1903.
So it seems desktop-icons NG wants me to enable WSL Interoperability, but I wasn't able to find out how to do it.
That said, I don't see what interoperability between Windows and Linux has to do with opening folders or pdf files on my desktop?!
My machines are dual boot. But my Ubuntu installations are independent of Windows. I'm certainly not running a Linux inside a Windows. So why does desktop-icons NG ask for WSL Interoperability?!
HuguesR
  • 113
This issue does not appear restricted to a dual boot environment. I had this problem as well and also solved it by uninstalling wslu. I do not have Windows or any other OS installed besides Kubuntu 22.04.
The output of command
sudo apt purge wslu
helps track down the dependency of wslu.
Your mileage may vary but in my case it was gimp-help-en:
The following package was automatically installed and is no longer required:
  gimp-help-common
Use 'sudo apt autoremove' to remove it.
The following packages will be REMOVED:
  gimp-help-en* wslu*
0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
After this operation, 63.8 MB disk space will be freed.
Do you want to continue? [Y/n]
When gimp is installed, a message "Language support is incomplete, additional packages are required" pops up in every session and a click to resolve the issue installs gimp's help. After that help was installed links to webpages did not work anymore.
In my installation wslu is indeed a dependency of gimp's help. I can verify that by manually installing apt install gimp-help-en and see that wslu will be installed as well (and will need to be removed again).
I have looked into the dependencies of gimp-help-en with command apt depends gimp-help-en and gimp-help-en depends on virtual package www-browser. www-browser is satisfied by many packages, among them chromium-browser, firefox, konqueror and also wslu. In Ubuntu 20.04 and earlier firefox was installed by default and gimp-help-en's dependency was satifisfied; in Ubuntu 22.04 firefox is not a package anymore but a snap and installing gimp-help-en also installed wslu.
In my case, this issue was a side-effect of Canonical turning firefox into a snap in Ubuntu 22.04. If I had installed chromium-browser, konqueror or firefox as a package, dependency www-browser would not have installed wslu and I would not have had this issue.
The downside of removing wslu as the fix is that not just wslu is removed but also the packages that caused it to be installed, in my case gimp-help-en. After removing gimp-help-en and wslu message "Language support is incomplete, additional packages are required" pops up again in every session and should I give in and click on this message gimp-help-en and wslu will be installed again and the issue will be back.
The best solution that I found is to install another package that also satisfies www-browser before removing wslu. This way, only wslu will be removed. This worked fine for me:
sudo apt install firefox
sudo apt purge wslu
where package firefox does not actually install firefox as a package; it just links to the snap. Installing it satisfies the dependency www-browser. Any other package besides firefox that satisfies www-browser should work as well, e.g. chromium-browser, konqueror or lynx.
sudo apt purge wslu
I had this problem on a Mac Mini with a fresh independent machine install. After purging wslu, bingo! The desktop files once again open on the desktop.
NotTheDr01ds
  • 22,082
