I have a laptop with two mount points, one with the system (/) and another with the /home folder. My user folder in /home was encrypted with Ubuntu 20.04.
This morning I re-installed the system with the new Ubuntu 22.04 ISO. I formatted the system partition and let the /home partition be. I provided the same user name and password as explained in this earlier answer.
Logging in Ubuntu 22.04 is not decrypting the user home folder. Most applications fail to start as they are not able to write in the user home.
I have both the log-in password and the passphrase
necessary to decrypt the home folder. Therefore I tried to decrypt the folder manually, but
ecryptfs-recover-private returns an error (see below).
How can I mount the user home folder encrypted by Ubuntu 20.04?
$ sudo ecryptfs-recover-private /home/lads/.Private
INFO: Found [/home/duque004/.Private].
Try to recover this directory? [Y/n]: Y
INFO: Found your wrapped-passphrase
Do you know your LOGIN passphrase? [Y/n] Y
INFO: Enter your LOGIN passphrase...
Passphrase:
Inserted auth tok with sig [3c9323dd0ed2026f] into the user session keyring
mount: /tmp/ecryptfs.6IGtBsCb: mount(2) system call failed: No such file or directory.
ERROR: Failed to mount private data at [/tmp/ecryptfs.6IGtBsCb].
Update: I found an old thread at the Arch Linux forum reporting a similar issue and providing a workaround, manually mounting the encrypted volume. This method succeeds in mounting the volume and showing the contents of the folder tree root, but it does not provide access to any files or folders. Log below, changing dir, listing or copying any of the contents in mnt/bck fails.
# cd /home/.ecryptfs/lads/.ecryptfs
ecryptfs-unwrap-passphrase ./wrapped-passphrase
Passphrase:
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ecryptfs-add-passphrase --fnek
Passphrase:
Inserted auth tok with sig [aaaaaaaaaaaa] into the user session keyring
Inserted auth tok with sig [bbbbbbbbbbbb] into the user session keyring
mount -t ecryptfs /home/.ecryptfs/lads/.Private /mnt/bck
Select key type to use for newly created files:
- tspi
- passphrase
Selection: 2
Passphrase:
Select cipher:
- aes: blocksize = 16; min keysize = 16; max keysize = 32
- blowfish: blocksize = 8; min keysize = 16; max keysize = 56
- des3_ede: blocksize = 8; min keysize = 24; max keysize = 24
- twofish: blocksize = 16; min keysize = 16; max keysize = 32
- cast6: blocksize = 16; min keysize = 16; max keysize = 32
- cast5: blocksize = 8; min keysize = 5; max keysize = 16
Selection [aes]:
Select key bytes:
- 16
- 32
- 24
Selection [16]:
Enable plaintext passthrough (y/n) [n]: n
Enable filename encryption (y/n) [n]: y
Filename Encryption Key (FNEK) Signature [aaaaaaaaaaaa]: bbbbbbbbbbbb
Attempting to mount with the following options:
ecryptfs_unlink_sigs
ecryptfs_fnek_sig=bbbbbbbbbbbb
ecryptfs_key_bytes=16
ecryptfs_cipher=aes
ecryptfs_sig=aaaaaaaaaaaa
Mounted eCryptfs
ls /mnt/bck | grep git
git
ls -la /mnt/bck/git
ls: cannot access '/mnt/bck/git': No such file or directory
cp /mnt/bck/.bash*
ls: cannot access '/mnt/bck/.bash_aliases': No such file or directory
ls: cannot access '/mnt/bck/.bash_history': No such file or directory
ls: cannot access '/mnt/bck/.bash_logout': No such file or directory
ls: cannot access '/mnt/bck/.bashrc': No such file or directory
