first time poster but I've been using Linux for a while but I'm far from grasping the operating system. Any time there's an error that pops up when I'm doing stuff, it crashes my brain because I haven't a clue what to do.
With that said, I'm trying to install bleachbit (or any software) for that matter and it seems I keep getting the same errors. For example, I'm trying to install bleachbit via terminal and here's what I get:
ubuntu@ubuntu-desktop:~$ sudo apt install bleachbit
[sudo] password for ubuntu:
Reading package lists... Done
Building dependency tree... Done
You might want to run 'apt --fix-broken install' to correct these.
linux-modules-5.15.0-25-generic : Depends: linux-image-5.15.0-25-generic but it is not going to be installed or
linux-image-unsigned-5.15.0-25-generic but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
If I try via the Software interface, I get:
Unable to install Bleachbit: Error while installing package: installed linux-image-5.15.0-25-generic package post-removal script subprocess returned error exit status 1
I'm running version 22.04.
I would love to know how to fix this. I checked devices and locations and it says I have 212.2 GB available on ubuntu-desktop.
This is what happens if I try to do the command:
sudo apt install linux-image-5.15.0-25-generic
If I try the command:
sudo apt install linux-modules-5.15.0-25-generic
Lastly if I try:
sudo apt full-upgrade
Here is df -h;df -i
Here is apt-mark showmanual | grep linux-'[g|i|m|h]'
ubuntu@ubuntu-desktop:~$ apt-mark showmanual | grep linux-'[g|i|m|h]' linux-generic-hwe-22.04 linux-image-5.15.0-25-generic linux-modules-5.15.0-25-generic
