I just installed Ubuntu 22.04 and installed Arduino using
snap install arduino
which installed as expected. I am aware I need to add my user to the dialout group, so I searched /dev for ttyACM* and also ttyUSB* using: sudo ls -al /dev/ttyUSB* and sudo ls -al /dev/ttyACM* but got
ls: cannot access '/dev/ttyUSB*': No such file or directory
and
ls: cannot access '/dev/ttyACM*': No such file or directory
I checked the ringbuffer for either of those using
sudo dmesg | grep tty
and got the following output:
[    0.167893] printk: console [tty0] enabled
[   86.158991] usb 2-2: FTDI USB Serial Device converter now attached to ttyUSB0
[   88.005204] usb 2-2: usbfs: interface 0 claimed by ftdi_sio while 'brltty' sets config #1
[   88.006033] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[ 1578.498248] usb 2-2: FTDI USB Serial Device converter now attached to ttyUSB0
[ 1580.221903] usb 2-2: usbfs: interface 0 claimed by ftdi_sio while 'brltty' sets config #1
[ 1580.223379] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[ 1714.844660] usb 2-2: FTDI USB Serial Device converter now attached to ttyUSB0
[ 1716.573774] usb 2-2: usbfs: interface 0 claimed by ftdi_sio while 'brltty' sets config #1
[ 1716.574710] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
So ttyUSB0 does seem to be there.
It doesnt seem to be permissions (I think) since its not saying "Permission denied".
I also tried adding to the udev rules: sudoedit /etc/udev/rules.d/50-myusb.rules and added the following lines: KERNEL=="ttyUSB[0-9]*",MODE="0666"
KERNEL=="ttyACM[0-9]*",MODE="0666"
then saved and logged out and back in, but no change. I also tried rebooting, just to be sure.
I'm not sure how to proceed from here, can anyone please point me in the right direction?
For anyone else running into this same problem, here's what I found that worked for me.
After more searching I found this link.
I removed brltty using the command: sudo apt remove brltty then rebooted.
After that when I ran: sudo dmesg -w and then plugged in the Arduino, I could see it and it was now able to be found under /dev/ttyUSB0.
Now I can program my Arduino!
