Can it cause problem?
Memtest86+ needs a 16-bit boot, that is not available on EFI, exiting
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
Adding boot menu entry for UEFI Firmware Settings ...
done
karel
  • 122,292
  • 133
  • 301
  • 332
Open your Terminal (CTRL+ALT+T) then type...
sudo nano /etc/default/grub
then add this line:
GRUB_DISABLE_OS_PROBER=false
to the grub configurations. Then in the terminal run...
sudo update-grub
then reboot.
Nmath
  • 12,664
