I need to install fuse on Ubuntu 22.04. I've tried installing via snap install fuse but that didn't work, so what is the safest way to install fuse on Ubuntu 22.04? Thanks!
- 144
See this: https://github.com/AppImage/AppImageKit/wiki/FUSE
For example, on Ubuntu (>= 22.04):
Warning: Do not install the fuse package as of 22.04 or > you may break your system
sudo add-apt-repository universe sudo apt install libfuse2
- 393
Update november 2024 WARNING: The information below is not anymore applicable for versions of Ubuntu > 24.04. Installing either fuse or fuse2 on more recent versions of Ubuntu may break the system.
fuse is present in the Ubuntu repositories, and therefore can be safely installed.
However, it conflicts with a newer version of fuse, fuse3, which is installed by default. If you choose to use fuse rather than fuse3, you will lose some functionality that depends on fuse3.
Installing fuse indeed will cause the removal of
fuse3 gnome-shell-extension-desktop-icons-ng gvfs-fuse ntfs-3g
xdg-desktop-portal xdg-desktop-portal-gnome
xdg-desktop-portal-gtk
In addition, the metapackages ubuntu-desktop and ubuntu-desktop-minimal will be removed.
fuse is in the software repository. Installation therefore is safe:
sudo apt install fuse
but you have to accept the consequences on functionality of the default desktop.
- 97,564
If the fuse package did break your system, you can recover as follows:
- After starting Ubuntu, enter the console by pressing Alt+Ctrl+F1. Then log in with your user account.
- Or boot into the Recovery Mode (https://wiki.ubuntu.com/RecoveryMode). Then chose
networkandroot. - Execute the command
sudo apt purge gdm3 && apt install gdm3 && reboot
- 95
