I have a clean installation of Ubuntu 22.04 on a remote machine that I can reach only via ssh (I have no physical access). I want to enable the remote desktop protocol (RDP). In this article the procedure seems simple: open Gnome Settings > Sharing and enable Remote Desktop and Remote Control; unfortunately it requires to use the Gnome GUI that I can not access. Looking around the web I found that this commands
$ gsettings set org.gnome.desktop.remote-desktop.vnc view-only false
$ gsettings set org.gnome.desktop.remote-desktop.vnc auth-method 'password'
$ systemctl --user start gnome-remote-desktop
$ systemctl --user status gnome-remote-desktop
● gnome-remote-desktop.service - GNOME Remote Desktop
     Loaded: loaded (/usr/lib/systemd/user/gnome-remote-desktop.service; enabled; vendor preset: enabled)
     Active: active (running) since Thu 2022-05-19 13:41:30 CEST; 11s ago
   Main PID: 50884 (gnome-remote-de)
      Tasks: 5 (limit: 2205)
     Memory: 21.9M
        CPU: 36ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/gnome-remote-desktop.service
             └─50884 /usr/libexec/gnome-remote-desktop-daemon
mag 19 13:41:30 OMISSIS systemd[50403]: Starting GNOME Remote Desktop... mag 19 13:41:30 OMISSIS systemd[50403]: Started GNOME Remote Desktop.
should be part of the solution, however they are not enough as I still can not connect to the remote machine using my remote desktop client (I am using Microsoft Remote Desktop from a late 2011 Mackbook pro running MacOS 10.13.6). The error I get is:
Unable to connect
We couldn't connect to the remote PC. Make sure the PC is turned on and connected to the network, and that remote access is enabled.
Error code: 0x204
I suppose I still have to do something on the remote machine.
Sirion
  • 221
