Since I use 2 daily driver OSs (Linux & MacOS), I realized that, on MacOS, when you press down on the touchpad with your finger, it clicks on the button (or whatever you're hovering over), but if you push it down with something else (like a pencil or something) it will not click.
This is not the case with my Ubuntu laptop. On Ubuntu, as long as the trackpad is pressed down all the way, the OS will register a click (so it will register a click no matter what is touching it). Is there a way to make it so it will only press down if it senses the finger on top of the trackpad?
On Mac when you click all the way down with another item the trackpad doesn't trigger. On Ubuntu it does trigger.
Since this was unclear: MacOS and Ubuntu are on two separate laptops (I do not have MacOS running on a Dell laptop or anything)
AFT
  • 1,687
I am pretty certain the answer is no, you can't get your Dell to behave like that.
This is a hardware difference, nothing to do with the OS. The responding to a finger but not the pencil etc. is similar behaviour to the home button on previous iphones: take the iphone 6 and earlier, the button clicked whether the phone was on or off: it's a physical button. The 7 onwards (until they abolished it) uses a taptic engine to generate a click when the device detects your finger. I bet if you turn off your Dell and press on the trackpad you'll get a click as it's a physical 'button' of sorts, on the Mac it'll go dead when the machine is off.
Aside from the clicking feeling itself, if you like the behaviour of being able to click by tapping with a finger but not an inanimate object, this might help: In settings, under 'mouse and touchpad', there's a setting 'Tap to click': check that that is enabled (I think it is by default; basically it allows you to tap lightly on the touchpad as a left click). That action will only work with skin contact, not things like pencils.
If you are concerned about accidentally clicking with other things, you could disable the physical buttons if you like too, leaving you with just a light tap on the touchpad to 'left-click': see this post How to disable physical mouse buttons below touchpad
It's not the complete deal in terms of turning your Dell touchpad into a Mac's, but it does emulate some of the behaviours.
Will
  • 2,483
  • 20
  • 34
