Situation: I'm stuck at a boot loop after trying to set up a dual boot on my Thinkpad 470 using a Rufus bootable pen drive and Ubuntu desktop LTS.
Goal: Be able to boot windows.
Details: I have a very similar issue to this guy here "Reset System", bootloop after attempting to dual boot although I wasn`t following the same tutorial. After finishing the installation I got a fatal error message and when I tried to restart my computer it would show "Reset system" on the top left corner and restart the computer in a loop.
I tried the boot repair tool, but it didn't work. I went back on the try Ubuntu and runned some commands from other posts.
sudo dmidecode -s bios-version gave me this: N1QET92W (1.67 )
sudo update-grub gave me this: /usr/sbin/grub-probe: error: failed to get canonical path of `/cow'.
I also runned sudo fdisk -l and saved the result, I can paste it here if needed.
I went on the Bios to change the boot order several times, but Ubuntu would always stay at the top, even after changing it to the bottom or even deleting it. So, I went on GParted and completely deleted all the partitions that I made for Ubuntu. The "reset system" loop stopped after doing this but now I am seeing a boot menu with two options, ATA HDD0 : ST500LM021-1KJ152 and PCI LAN, if I select one them the screen goes black for a moment but then the menu reappears, in a loop.
If I'm using the default settings on the BIOS(UEFI), I go straight up to this boot menu, but if I'm using Legacy Mode, I'll first see a screen saying "Intel Boot agent" and Initializing and establishing link below. Then it will show PXE-E61: Media test failure, check cables and PXE-M0F: Exiting Intel Boot Agent and then it will show the same boot menu.
Thanks in advance for any help, if there's any command that I should run, picture or information that could help just let me know.
