After running sudo apt-get install build-essential
I got
Reading package lists... Done
Building dependency tree... Done
The following additional packages will be installed:
dpkg-dev fakeroot g++ g++-11 gcc gcc-11 libalgorithm-diff-perl libalgorithm-diff-xs-perl libalgorithm-merge-perl
libasan6 libfakeroot libgcc-11-dev libstdc++-11-dev lto-disabled-list
Suggested packages:
debian-keyring g++-multilib g++-11-multilib gcc-11-doc gcc-multilib autoconf automake libtool flex bison gcc-doc
gcc-11-multilib gcc-11-locales libstdc++-11-doc
The following NEW packages will be installed:
build-essential dpkg-dev fakeroot g++ g++-11 gcc gcc-11 libalgorithm-diff-perl libalgorithm-diff-xs-perl
libalgorithm-merge-perl libasan6 libfakeroot libgcc-11-dev libstdc++-11-dev lto-disabled-list
0 upgraded, 15 newly installed, 0 to remove and 0 not upgraded.
Need to get 2,283 kB/39.5 MB of archives.
After this operation, 128 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://in.archive.ubuntu.com/ubuntu jammy/main amd64 libasan6 amd64 11.2.0-19ubuntu1 [2,283 kB]
Err:1 http://in.archive.ubuntu.com/ubuntu jammy/main amd64 libasan6 amd64 11.2.0-19ubuntu1
Hash Sum mismatch
Hashes of expected file:
- SHA512:879b51c208b36729446f0652016d4b3731a7e742a67ce84240122cd88714cb4b548950edb6f0723e296dd7f0621a6dd84823c6087b87bc1519c17e09cbb07656
- SHA256:94d9f1889bdec4aef6a37f8afd84346e1bcdaa65c158f5647b09781c1f4401e4
- SHA1:7a40b9444a06b644a72485a4cfedd828dd43ad19 [weak]
- MD5Sum:d88dd5768dcbf199a2dacfbbbbccb405 [weak]
- Filesize:2283282 [weak]
Hashes of received file:
- SHA512:4625ca49a97b8e1491835c2be9ddaf6349bc7f994eb653ec7007bb2e8e198e11cb8f81775ecb005bf8b5596319f37504103d908e7497a123b4518a2e6f9cbfe5
- SHA256:f9e9c4713e0596f4cff736d61591a91dfb75427749ab2d4b33790eba7545e591
- SHA1:966a7d0cedf809a5fba8009b770e442ed6191d9f [weak]
- MD5Sum:30f1f833b5c6543d09d5325d8b0dffa4 [weak]
Last modification reported: Thu, 24 Mar 2022 17:54:28 +0000
Fetched 2,283 kB in 1s (3,666 kB/s)
E: Failed to fetch http://in.archive.ubuntu.com/ubuntu/pool/main/g/gcc-11/libasan6_11.2.0-19ubuntu1_amd64.deb Hash Sum mismatch
Then as suggested I ran sudo apt-get install build-essential --fix-missing which gave this error
Suggested packages:
Hash Sum mismatch
Fetched 2,283 kB in 1s (4,052 kB/s)
Selecting previously unselected package libgcc-11-dev:amd64.
(Reading database ... 217900 files and directories currently installed.)
Preparing to unpack .../00-libgcc-11-dev_11.2.0-19ubuntu1_amd64.deb ...
Unpacking libgcc-11-dev:amd64 (11.2.0-19ubuntu1) ...
Selecting previously unselected package gcc-11.
Preparing to unpack .../01-gcc-11_11.2.0-19ubuntu1_amd64.deb ...
Unpacking gcc-11 (11.2.0-19ubuntu1) ...
Selecting previously unselected package gcc.
Preparing to unpack .../02-gcc_4%3a11.2.0-1ubuntu1_amd64.deb ...
Unpacking gcc (4:11.2.0-1ubuntu1) ...
Selecting previously unselected package libstdc++-11-dev:amd64.
Preparing to unpack .../03-libstdc++-11-dev_11.2.0-19ubuntu1_amd64.deb ...
Unpacking libstdc++-11-dev:amd64 (11.2.0-19ubuntu1) ...
Selecting previously unselected package g++-11.
Preparing to unpack .../04-g++-11_11.2.0-19ubuntu1_amd64.deb ...
Unpacking g++-11 (11.2.0-19ubuntu1) ...
Selecting previously unselected package g++.
Preparing to unpack .../05-g++_4%3a11.2.0-1ubuntu1_amd64.deb ...
Unpacking g++ (4:11.2.0-1ubuntu1) ...
Selecting previously unselected package lto-disabled-list.
Preparing to unpack .../06-lto-disabled-list_24_all.deb ...
Unpacking lto-disabled-list (24) ...
Selecting previously unselected package dpkg-dev.
Preparing to unpack .../07-dpkg-dev_1.21.1ubuntu2_all.deb ...
Unpacking dpkg-dev (1.21.1ubuntu2) ...
Selecting previously unselected package build-essential.
Preparing to unpack .../08-build-essential_12.9ubuntu3_amd64.deb ...
Unpacking build-essential (12.9ubuntu3) ...
Selecting previously unselected package libfakeroot:amd64.
Preparing to unpack .../09-libfakeroot_1.28-1ubuntu1_amd64.deb ...
Unpacking libfakeroot:amd64 (1.28-1ubuntu1) ...
Selecting previously unselected package fakeroot.
Preparing to unpack .../10-fakeroot_1.28-1ubuntu1_amd64.deb ...
Unpacking fakeroot (1.28-1ubuntu1) ...
Selecting previously unselected package libalgorithm-diff-perl.
Preparing to unpack .../11-libalgorithm-diff-perl_1.201-1_all.deb ...
Unpacking libalgorithm-diff-perl (1.201-1) ...
Selecting previously unselected package libalgorithm-diff-xs-perl.
Preparing to unpack .../12-libalgorithm-diff-xs-perl_0.04-6build3_amd64.deb ...
Unpacking libalgorithm-diff-xs-perl (0.04-6build3) ...
Selecting previously unselected package libalgorithm-merge-perl.
Preparing to unpack .../13-libalgorithm-merge-perl_0.08-3_all.deb ...
Unpacking libalgorithm-merge-perl (0.08-3) ...
Setting up lto-disabled-list (24) ...
Setting up libalgorithm-diff-perl (1.201-1) ...
Setting up libfakeroot:amd64 (1.28-1ubuntu1) ...
Setting up dpkg-dev (1.21.1ubuntu2) ...
Setting up fakeroot (1.28-1ubuntu1) ...
update-alternatives: using /usr/bin/fakeroot-sysv to provide /usr/bin/fakeroot (fakeroot) in auto mode
dpkg: dependency problems prevent configuration of libgcc-11-dev:amd64:
libgcc-11-dev:amd64 depends on libasan6 (>= 11.2.0-19ubuntu1); however:
Package libasan6:amd64 is not installed.
dpkg: error processing package libgcc-11-dev:amd64 (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of gcc-11:
gcc-11 depends on libgcc-11-dev (= 11.2.0-19ubuntu1); however:
Package libgcc-11-dev:amd64 is not configured yet.
dpkg: error processing package gcc-11 (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
Setting up libalgorithm-diff-xs-perl (0.04-6build3) ...
Setting up libalgorithm-merge-perl (0.08-3) ...
dpkg: dependency problems prevent configuration of g++-11:
g++-11 depends on gcc-11 (= 11.2.0-19ubuntu1); however:
Package gcc-11 is not configured yet.
dpkg: error processing package g++-11 (--configure):
No apport report written because MaxReports is reached already
dpkg: dependency problems prevent configuration of gcc:
gcc depends on gcc-11 (>= 11.2.0-1~); however:
dpkg: error processing package gcc (--configure):
dpkg: dependency problems prevent configuration of libstdc++-11-dev:amd64:
libstdc++-11-dev:amd64 depends on libgcc-11-dev (= 11.2.0-19ubuntu1); however:
dpkg: error processing package libstdc++-11-dev:amd64 (--configure):
dpkg: dependency problems prevent configuration of g++:
g++ depends on gcc (= 4:11.2.0-1ubuntu1); however:
Package gcc is not configured yet.
g++ depends on g++-11 (>= 11.2.0-1~); however:
Package g++-11 is not configured yet.
g++ depends on gcc-11 (>= 11.2.0-1~); however:
dpkg: error processing package g++ (--configure):
dpkg: dependency problems prevent configuration of build-essential:
build-essential depends on gcc (>= 4:10.2); however:
build-essential depends on g++ (>= 4:10.2); however:
Package g++ is not configured yet.
dpkg: error processing package build-essential (--configure):
Processing triggers for man-db (2.10.2-1) ...
Processing triggers for libc-bin (2.35-0ubuntu3) ...
libgcc-11-dev:amd64
gcc-11
g++-11
gcc
g++
build-essential
<br><br>
Also tried to fix broken packages sudo apt --fix-broken install <br><br>
Correcting dependencies... Done
libasan6
libasan6
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
7 not fully installed or removed.
Need to get 2,283 kB of archives.
After this operation, 7,697 kB of additional disk space will be used.
Hash Sum mismatch
Fetched 2,283 kB in 1s (4,472 kB/s)
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
But, nah nothing working need assistance to run g++ on my Kubuntu. There seems to be some issue with a single package libasan6. (Also can't update it from discover)
