I'm trying to change the default OS in grub, but when I do
sudo gedit /boot/grub/grub.cfg and change it to option 3 instead of 0 and run update-grub, nothing changes. The default selected OS is still the first one and when I look in grub.cfg it's back to 0. What am I doing wrong?
Braiam
  • 69,112
PatronBernard
  • 53
As stated on the top of /boot/grub/grub.cfg:
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
Edit /etc/default/grub instead.
Here are details on how to configure the grub file; see the other answers there for a GUI-based method.
Chan-Ho Suh
  • 7,582
  • 43
  • 74
For a small change, just save grub.cfg without update-grub afterwards.
Just realize that anything you do will revert to the information in the scripts the next time update-grub is called.
Thus the reason we don't edit grub.cfg directly.
JohnWayne
  • 29
I forgot about a GRUB installation from source into the /usr/local prefix which was reading /usr/local/etc/default/grub. I removed /usr/local/sbin/grub-mkconfig and reinstalled the system packages and it works as expected, now.
