I installed chrome remote desktop in Ubuntu 18.04.
First issue, I can't add a new device which solved by:
Can't set up remote access on chrome remote desktop
The current issue, the connection is always disconnected when trying to connect from other devices.
When login ( enter the pin code ), it will show a session selection screen. Whatever I choose, both get an end connection immediately.
The options are:
  1. (default) Launch the default XSession.
  2. Ubuntu This session logs you into Ubuntu.
PS.
  1. The pin code is correct.
  2. If I use Remote Support function which generated the one-time connection code, it works normally.
Mark Kang
  • 151
The user needs to log out first in the local machine.
Mark Kang
  • 151
