Specifically, when trying to install freeglut3-dev, I get an error of broken dependencies. I already tried with the classic: fixing the packages and different methods that I found, but nothing is fixing this error. My system is Ubuntu 18.04
sudo apt-get update --fix-missing
sudo dpkg --configure -a
sudo apt-get install -f
sudo apt upgrade
The error When installing:
sudo apt-get install freeglut3-dev
Reading package lists... Done
Building dependency tree
freeglut3-dev : Depends: libgl1-mesa-dev but it is not going to be installed or
libgl-dev
Depends: libglu1-mesa-dev but it is not going to be installed or
libglu-dev
Previous to this, I was having a lot of issues with nvidia, cuda and cudnn, so if I recall properly, I think I added some local repos (added ppas, but not sure) from a university in China . To install some versions of CUDA, those versions worked for Ubuntu 16.04, so this might be making the error. When doing apt update, I don't recall seeing before the format of GET IGN of a file like
Get:1 file:/var/cuda-repo-ubuntu1804-11-6-local InRelease
Ign:1 file:/var/cuda-repo-ubuntu1804-11-6-local InRelease
But I really am very lost and have been working around this for some time. If my guess is right, deleting those should fix this. But I am not sure if that's the correct answer, or even how to do it.
sudo apt update
Get:2 file:/var/cudnn-local-repo-ubuntu1804-8.4.0.27 InRelease
Ign:2 file:/var/cudnn-local-repo-ubuntu1804-8.4.0.27 InRelease
Get:3 file:/var/cuda-repo-ubuntu1804-11-6-local Release [564 B]
Get:4 file:/var/cudnn-local-repo-ubuntu1804-8.4.0.27 Release [564 B]
Hit:5 https://nvidia.github.io/libnvidia-container/stable/ubuntu18.04/amd64 InRelease
Hit:6 https://download.docker.com/linux/ubuntu bionic InRelease
Hit:7 https://nvidia.github.io/nvidia-container-runtime/stable/ubuntu18.04/amd64 InRelease
Hit:8 https://nvidia.github.io/nvidia-docker/ubuntu18.04/amd64 InRelease
Hit:9 https://linux.teamviewer.com/deb stable InRelease
Hit:11 http://es.archive.ubuntu.com/ubuntu bionic InRelease
Hit:12 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu bionic InRelease
Hit:13 http://es.archive.ubuntu.com/ubuntu bionic-backports InRelease
Hit:14 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic InRelease
Hit:15 http://security.ubuntu.com/ubuntu bionic-security InRelease
Hit:17 http://ppa.launchpad.net/obsproject/obs-studio/ubuntu bionic InRelease
Hit:18 https://packagecloud.io/AtomEditor/atom/any any InRelease
All packages are up to date.
Edit: I just checked my history browser to make sure about the adding repos, and I think it was just for conda, not particularly for ubuntu but again, I am not sure if it has any impact. Not an Ubuntu expert:
conda config --add channels https://mirrors.ustc.edu.cn/anaconda/pkgs/main/
Maybe when I tried this sudo apt-get install g++ freeglut3-dev build-essential libx11-dev libxmu-dev libxi-dev libglu1-mesa libglu1-mesa-dev and
wget https://developer.nvidia.com/compute/cuda/9.0/Prod/local_installers/cuda_9.0.176_384.81_linux-run
Edit 2: Output of
grep -Rn --include=*.list ^[^#] /etc/apt/
/etc/apt/sources.list:5:deb http://es.archive.ubuntu.com/ubuntu/ bionic main restricted
/etc/apt/sources.list:15:deb http://es.archive.ubuntu.com/ubuntu/ bionic universe
/etc/apt/sources.list:24:deb http://es.archive.ubuntu.com/ubuntu/ bionic multiverse
/etc/apt/sources.list:33:deb http://es.archive.ubuntu.com/ubuntu/ bionic-backports main restricted universe multiverse
/etc/apt/sources.list:43:deb http://security.ubuntu.com/ubuntu bionic-security main restricted
/etc/apt/sources.list:45:deb http://security.ubuntu.com/ubuntu bionic-security universe
/etc/apt/sources.list:47:deb http://security.ubuntu.com/ubuntu bionic-security multiverse
/etc/apt/sources.list:49:deb [arch=amd64] https://packagecloud.io/AtomEditor/atom/any/ any main
/etc/apt/sources.list:51:deb [arch=amd64] https://download.docker.com/linux/ubuntu bionic stable
/etc/apt/sources.list.d/cuda-ubuntu1804-11-6-local.list:1:deb file:///var/cuda-repo-ubuntu1804-11-6-local /
/etc/apt/sources.list.d/deadsnakes-ubuntu-ppa-bionic.list:1:deb http://ppa.launchpad.net/deadsnakes/ppa/ubuntu bionic main
/etc/apt/sources.list.d/nvidia-docker.list:1:deb https://nvidia.github.io/libnvidia-container/stable/ubuntu18.04/$(ARCH) /
/etc/apt/sources.list.d/nvidia-docker.list:3:deb https://nvidia.github.io/nvidia-container-runtime/stable/ubuntu18.04/$(ARCH) /
/etc/apt/sources.list.d/nvidia-docker.list:5:deb https://nvidia.github.io/nvidia-docker/ubuntu18.04/$(ARCH) /
/etc/apt/sources.list.d/cudnn-local-ubuntu1804-8.4.0.27.list:1:deb file:///var/cudnn-local-repo-ubuntu1804-8.4.0.27 /
/etc/apt/sources.list.d/teamviewer.list:19:deb https://linux.teamviewer.com/deb stable main
/etc/apt/sources.list.d/obsproject-ubuntu-obs-studio-bionic.list:1:deb http://ppa.launchpad.net/obsproject/obs-studio/ubuntu bionic main
/etc/apt/sources.list.d/graphics-drivers-ubuntu-ppa-bionic.list:1:deb http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic main
