cannot install wine7 on ubuntu 22.04
i have used the instructions on winehq but got
winehq-stable : Depends: wine-stable (= 7.0.0.0~focal-1)
The instructions on winehq:
$ sudo dpkg --add-architecture i386
which have no output
then
wget -nc https://dl.winehq.org/wine-builds/winehq.key
outputs
--2022-05-08 12:41:22-- https://dl.winehq.org/wine-builds/winehq.key
Connecting to 127.0.0.1:7899... connected.
Proxy request sent, awaiting response... 200 OK
Length: 3220 (3.1K) [application/pgp-keys]
Saving to: ‘winehq.key’
winehq.key 100%[============================>] 3.14K --.-KB/s in 0s
2022-05-08 12:41:24 (41.3 MB/s) - ‘winehq.key’ saved [3220/3220]
then
sudo mv winehq.key /usr/share/keyrings/winehq-archive.key
which is a move
then
wget -nc https://dl.winehq.org/wine-builds/ubuntu/dists/jammy/winehq-jammy.sources
output:
--2022-05-08 12:43:36-- https://dl.winehq.org/wine-builds/ubuntu/dists/jammy/winehq-jammy.sources
Length: 165
Saving to: ‘winehq-jammy.sources’
winehq-jammy.sources 100%[============================>] 165 --.-KB/s in 0s
2022-05-08 12:43:38 (12.4 MB/s) - ‘winehq-jammy.sources’ saved [165/165]
then the
sudo apt update
output:
Hit:1 https://dl.google.com/linux/chrome/deb stable InRelease
Hit:2 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
Hit:4 https://dl.winehq.org/wine-builds/ubuntu focal InRelease
Hit:5 http://archive.ubuntu.com/ubuntu focal InRelease
Hit:6 https://dl.winehq.org/wine-builds/ubuntu jammy InRelease
Hit:7 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Reading package lists... Done
Building dependency tree... Done
3 packages can be upgraded. Run 'apt list --upgradable' to see them.
then for the stable branch
sudo apt install --install-recommends winehq-stable
output:
update
I have successfuly installed a wine with the
sudo apt install wine
command, but it doesn't have an interface and I don't know if it is working properly.
