19
I can't find fingerprint sensors settings in Ubuntu 22.04 installed on my notebook (XPS 13 Dell). I've tried "settings > Users", but there is no fingerprint option there. Do I have to install separately or it is provided by Ubuntu 22.04?
Mau35
  • 193
5 Answers5
22
Enabling fingerprint for login, screensaver unlock, graphical sudo password prompts in Ubuntu 22.04 on Dell Inspiron 14 7425 2-in-1 requires the following commands:
$ lsusb
Bus 003 Device 003: ID 27c6:639c Shenzhen Goodix Technology Co.,Ltd. Goodix USB2.0 MISC
$ sudo apt install fprintd libpam-fprintd
$ fprintd-enroll
$ sudo pam-auth-update --enable fprintd
Full details:
I'm also running the same setup and had the same issue but the fix is pretty straightforward. First of all makes sure that the OS recognises that the fingerprint sensor exists. You can do this by running
lsusb
You should see an entry that is about a fingerprint scanner. Then you can download and install the needed software with
wget http://dell.archive.canonical.com/updates/pool/public/libf/libfprint-2-tod1-goodix/libfprint-2-tod1-goodix_0.0.4-0ubuntu1somerville1_amd64.deb
sudo apt install ./libfprint-2-tod1-goodix_0.0.4-0ubuntu1somerville1_amd64.deb
If you get any dependency errors just apt install the relevant dependency and try again. After you install everything you should be able to see a fingerprint option appear in the Users settings. According to the original source there is a reboot necessary.
Hope this helps!
Pilot6
  • 92,041
The Dell XPS 13 likely has a Goodix fingerprint reader, which is not open source. There were some updates to libfprint/fprintd that broke compatibility with the driver.
A bug report was opened and in the mean time this is fixed. Use the packages from Andy Chi as mentioned in the bug report to test: https://bugs.launchpad.net/libfprint-2-tod1-goodix/+bug/1966911
Multiple users ( including myself ) have reported this to work now, so I think the packages will be part of 22.04 soon, just keep an eye on the bug (they are in the proposed channel now, which you can enable to test too).
Note that if anything is not working as expected, there may be a configuration issue.
Please report if you have this working now and if not, check the bug report and provide details so you can be helped.
[update] A fix has been released as a result of the bug report. Make sure to read it and see if your problem is solved. A full update should give you a working setup if you were affected by the bug [/update]
When you installed the driver and restarted the OS but you still don't see the option Fingerprint Login in User Settings, you may try:
sudo service fprintd status
In my case the error was:
fprintd[12337]: Impossible to load module /usr/lib/x86_64-linux-gnu/libfprint-2/tod-1/libfprint-2-tod-1-broadcom.so: libcrypto.so.1.1: cannot open shared object file:>
I installed libssl:
sudo dpkg -i libssl1.1_1.1.1f-1ubuntu2.16_amd64.deb
And restarted fprintd service:
sudo service fprintd restart
After that service status shows: systemd[1]: Started Fingerprint Authentication Daemon and I could see the option Fingerprint Login in User Settings.
For Asus ExpertBook 2024 with a Focaltech fingerprint sensor, works with both Ubuntu 22.04 and Ubuntu 24.04.
Firstly, download the driver in .deb in the Focal repo.
Secondly, install the driver:
sudo dpkg -i ./libfprint-2-2_1.94.4+tod1-0ubuntu1\~22.04.2_amd64_20250219.deb
Thirdly, enable the fingerprint:
Finally, enroll your fingerprint.
fprintd-enroll
Mai Hai
  • 101
