Spare me as this is the first question I ever post in here.
So I tried to update on Ubuntu 22.04 using the command line and everything was fine until I got the error E: Sub-process /usr/bin/dpkg returned an error code (1)
Here:
Processing triggers for initramfs-tools (0.140ubuntu13) ...
update-initramfs: Generating /boot/initrd.img-5.15.0-27-lowlatency
I: The initramfs will attempt to resume from /dev/sda1
I: (UUID=d0783d7d-a3db-4dbb-a784-8b92c1aa4355)
I: Set the RESUME variable to override this.
zstd: error 25 : Write error : No space left on device (cannot write compressed block)
E: mkinitramfs failure zstd -q -1 -T0 25 update-initramfs: failed for /boot/initrd.img-5.15.0-27-lowlatency with 1.
dpkg: error processing package initramfs-tools (--configure):
installed initramfs-tools package post-installation script subprocess returned
error exit status 1
initramfs-tools E: Sub-process /usr/bin/dpkg returned an error code (1) <
So, I really have no what is going on. The boot partition still has space in it and as far as I can see I can't install anything after I sudo apt update and then tried the sudo apt upgrade.
It is only recently that I started using Linux and just began using Lubuntu 22.04.
Thanks in advance
