28
I upgraded a 16.04 Ubuntu server to 22.04. Migration to 18.04 and 20.04 worked well. However, the upgrade to 22.04 broke my DNS config.
I found a lot of tutorials to configure the whole network using netplan, but I don't feel very comfortable with them (I'm afraid that I will break everything). I have a lot of network interfaces on the server but nothing in /etc/netplan.
I wonder if I have to create a netplan file with all the network interfaces or just the broken one.
Here is the result of nmcli device show command:
GENERAL.DEVICE:                         docker0
GENERAL.TYPE:                           bridge
GENERAL.HWADDR:                         02:42:99:76:F4:CE
GENERAL.MTU:                            1500
GENERAL.STATE:                          10 (non-géré)
GENERAL.CONNECTION:                     --
GENERAL.CON-PATH:                       --
IP4.ADDRESS[1]:                         172.17.0.1/16
IP4.GATEWAY:                            --
IP4.ROUTE[1]:                           dst = 172.17.0.0/16, nh = 0.0.0.0, mt = 0
IP6.GATEWAY:                            --
GENERAL.DEVICE: docker_gwbridge GENERAL.TYPE: bridge GENERAL.HWADDR: 02:42:FA:EB:F8:75 GENERAL.MTU: 1500 GENERAL.STATE: 10 (non-géré) GENERAL.CONNECTION: -- GENERAL.CON-PATH: -- IP4.ADDRESS[1]: 172.18.0.1/16 IP4.GATEWAY: -- IP4.ROUTE[1]: dst = 172.18.0.0/16, nh = 0.0.0.0, mt = 0 IP6.ADDRESS[1]: fe80::42:faff:feeb:f875/64 IP6.GATEWAY: -- IP6.ROUTE[1]: dst = fe80::/64, nh = ::, mt = 256
GENERAL.DEVICE: enp2s0f0 GENERAL.TYPE: ethernet GENERAL.HWADDR: D8:D3:85:B9:34:20 GENERAL.MTU: 1500 GENERAL.STATE: 10 (non-géré) GENERAL.CONNECTION: -- GENERAL.CON-PATH: -- WIRED-PROPERTIES.CARRIER: marche IP4.ADDRESS[1]: 10.231.226.41/23 IP4.GATEWAY: 10.231.227.254 IP4.ROUTE[1]: dst = 0.0.0.0/0, nh = 10.231.227.254, mt = 0 IP4.ROUTE[2]: dst = 10.231.226.0/23, nh = 0.0.0.0, mt = 0 IP6.ADDRESS[1]: fe80::dad3:85ff:feb9:3420/64 IP6.GATEWAY: -- IP6.ROUTE[1]: dst = fe80::/64, nh = ::, mt = 256
GENERAL.DEVICE: enp2s0f1 GENERAL.TYPE: ethernet GENERAL.HWADDR: D8:D3:85:B9:34:22 GENERAL.MTU: 1500 GENERAL.STATE: 10 (non-géré) GENERAL.CONNECTION: -- GENERAL.CON-PATH: -- WIRED-PROPERTIES.CARRIER: arrêt IP4.GATEWAY: -- IP6.GATEWAY: --
GENERAL.DEVICE: vethdcb1995 GENERAL.TYPE: ethernet GENERAL.HWADDR: C2:05:F6:52:3F:61 GENERAL.MTU: 1500 GENERAL.STATE: 10 (non-géré) GENERAL.CONNECTION: -- GENERAL.CON-PATH: -- WIRED-PROPERTIES.CARRIER: marche IP4.GATEWAY: -- IP6.ADDRESS[1]: fe80::c005:f6ff:fe52:3f61/64 IP6.GATEWAY: -- IP6.ROUTE[1]: dst = fe80::/64, nh = ::, mt = 256
GENERAL.DEVICE: lo GENERAL.TYPE: loopback GENERAL.HWADDR: 00:00:00:00:00:00 GENERAL.MTU: 65536 GENERAL.STATE: 10 (non-géré) GENERAL.CONNECTION: -- GENERAL.CON-PATH: -- IP4.ADDRESS[1]: 127.0.0.1/8 IP4.GATEWAY: -- IP6.ADDRESS[1]: ::1/128 IP6.GATEWAY: -- IP6.ROUTE[1]: dst = ::1/128, nh = ::, mt = 256
The problem is that the enp2s0f0 device has no DNS defined.
My questions are:
  1. How to add my DNS records safely? Maybe there's a clean solution easier than netplan. Clean excludes hacking files generated by generated by resolvconf like /etc/resolvconf/resolv.conf.d/head.
  2. If I have to create all interfaces in the file, is there a way to create a netplan file from the current settings to reduce the risk of errors?
PS: I do not know if it is important, but systemd-resolve is not installed on the machine and /etc/resolv.conf.d contains the following reference to it:
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
#     DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
# 127.0.0.53 is the systemd-resolved stub resolver.
# run "systemd-resolve --status" to see details about the actual nameservers.
nameserver 127.0.0.53 search DOMAINS
I finally found the solution here: https://serverok.in/systemd-resolved
In case the link die in the future: Create a file:
sudo mkdir /etc/systemd/resolved.conf.d/
sudo nano /etc/systemd/resolved.conf.d/dns_servers.conf
Add my dns in this file:
[Resolve]
DNS=8.8.8.8 1.1.1.1
Then restart systemd-resolved
sudo systemctl restart systemd-resolved
It works even after reboot :-)
PS : No idea why my DNS configuration was lost during the upgrade from 20.04 to 22.04.
I tried to apply the fix of Jean-Marc, but while it worked in the session, I actually lost the whole network configuration (including the IP) after the reboot. I had to create a YAML file with the whole configuration in /etc/netplan such as explained there : https://tecadmin.net/how-to-configure-static-ip-address-on-ubuntu-22-04/ Content of my 01-netcfg.yaml file:
network:
  ethernets:
    ensXX:
      addresses:
      - XXX.XXX.XXX.XX/XX
      routes:
      - to: default
        via: YOUR_GATEWAY
      nameservers:
        addresses:
        - YOUR_MAIN_DNS_IP
        - OTHER_DNS_IPS
        search:
        - MACHINE_DOMAIN_NAME
David SHainidze
  • 2,718
  • 13
