14
Today, I noticed that the directory /lib/modules still have all the directories from previously installed kernels, thus:
$ ls /lib/modules
5.4.0-29-generic  5.4.0-31-generic  5.4.0-33-generic  5.4.0-37-generic  5.4.0-39-generic
5.4.0-40-generic  5.4.0-42-generic  5.4.0-45-generic  5.4.0-47-generic  5.4.0-48-generic
...  etc.
In each of these directories, the following files are left (Intel/AMD system):
$ ls -l
-rw-r--r--  1 root 143K 2022-04-28 18:36 modules.alias
-rw-r--r--  1 root 154K 2022-04-28 18:36 modules.alias.bin
-rw-r--r--  1 root 8.0K 2022-04-08 10:44 modules.builtin
-rw-r--r--  1 root  25K 2022-04-28 18:36 modules.builtin.alias.bin
-rw-r--r--  1 root  11K 2022-04-28 18:36 modules.builtin.bin
-rw-r--r--  1 root  63K 2022-04-08 10:44 modules.builtin.modinfo
-rw-r--r--  1 root  85K 2022-04-28 18:36 modules.dep
-rw-r--r--  1 root 123K 2022-04-28 18:36 modules.dep.bin
-rw-r--r--  1 root  268 2022-04-28 18:36 modules.devname
-rw-r--r--  1 root 215K 2022-04-08 10:44 modules.order
-rw-r--r--  1 root  489 2022-04-28 18:36 modules.softdep
-rw-r--r--  1 root 279K 2022-04-28 18:36 modules.symbols
-rw-r--r--  1 root 326K 2022-04-28 18:36 modules.symbols.bin
And for a Raspberry Pi (notice the size differences):
-rw-r--r--  1 root 859K 2022-04-25 17:31 modules.alias
-rw-r--r--  1 root 893K 2022-04-25 17:31 modules.alias.bin
-rw-r--r--  1 root  11K 2022-04-04 13:33 modules.builtin
-rw-r--r--  1 root  27K 2022-04-25 17:31 modules.builtin.alias.bin
-rw-r--r--  1 root  14K 2022-04-25 17:31 modules.builtin.bin
-rw-r--r--  1 root  84K 2022-04-04 13:33 modules.builtin.modinfo
-rw-r--r--  1 root 399K 2022-04-25 17:31 modules.dep
-rw-r--r--  1 root 548K 2022-04-25 17:31 modules.dep.bin
-rw-r--r--  1 root  250 2022-04-25 17:31 modules.devname
-rw-r--r--  1 root 209K 2022-04-04 13:33 modules.order
-rw-r--r--  1 root  950 2022-04-25 17:31 modules.softdep
-rw-r--r--  1 root 354K 2022-04-25 17:31 modules.symbols
-rw-r--r--  1 root 425K 2022-04-25 17:31 modules.symbols.bin
For a system that's been running for 2 years with all kernel upgrades, this amounts to ~50 old directories. For a normal Intel/AMD system, it's around 100 Megabytes, and for a Raspberry Pi it's over 300 Megabytes in total - it will amount to something over time.
So I wonder why these old module directories and files for removed kernels aren't removed as part of the cleanup process?
I recently upgraded from Ubuntu 20.04 to 22.04 (which is why I'm doing some cleanup stuff anyway).
As things currently stand, I wonder if I should make my own cleanup script for these leftover directories. Still, I'm curious why it isn't done automatically.
Artur Meinild
  • 31,035
I don't know why
I don't think you will get a good answer to why Ubuntu does something the way it does something.
History
Up until some years ago Ubuntu didn't clean up any kernel and kernel header packages at all. Now Software Updates removes old and unused kernels. I think it runs something like:
sudo apt autoremove
Unfortunately it leaves those module files behind.
Moving forward
You don't have to write a script to get rid of them. The following command will do the job:
sudo apt --purge autoremove
Note, you have to run this command before Software Updates does its cleaning up.
Cleaning Up
As for the existing modules left behind, you will have to delete them manually, making sure you don't delete any module folders that are currently being used.
Use this command to find the list of installed kernels:
apt list --installed linux-image*
If Ubuntu has been removing old kernels then you should see two or three entries, including linux-image meta package linux-image-generic. Write down the kernel version numbers of the install kernels and make sure you don't delete the /lib/modules/ sub-folders for the installed kernels. Hope this helps
user68186
  • 37,461
Background Info
From the comments and @user68186's answer, I can now gather that the why implicitly follows the way apt works under the hood.
The module files in my question apparently falls under the category of config files, which means they are not removed with a normal apt autoremove, but only removed if you provide the --purge option.
However, especially for the Raspberry Pi (and possible other special architectures) those config files can at some point amount to gigabytes, if the system is running long enough with kernel updates.
So it's good to be aware of the sudo apt autoremove --purge option, which removes all previous kernel config files, including module configs.
Automated Kernel Management Tool
As indicated by @DougSmythies, there is an automated kernel management tool called linux-purge. I've tested this, and it seems to work well.
To install this utility, do the following (as root). This installs the script, the manpage and bash autocompletions.
$ wget https://git.launchpad.net/linux-purge/plain/update-linux-purge
$ chmod +x ./update-linux-purge && ./update-linux-purge
Now, you can use the utility with the command linux-purge, and its manual page is available with man linux-purge.
For instance, to purge all old kernels (that are not present inside /boot), run:
linux-purge -b
Ongoing Bug Report
Also, since the issue was reported on Ubuntu Discourse, a bug report has been opened to address this issue. Anyone interested can follow the progress there.
Artur Meinild
  • 31,035
for lazy bones like me. I created the file
cat /etc/apt/apt.conf.d/zz_purge
APT::Get::Purge "true";
Binary::apt::Purge "true";
APT::Get::AutomaticRemove "true"; APT::Get::Purge-Unused "true"; Binary::apt::APT::Purge-Unused "true"; Binary::apt::APT::AutomaticRemove "true";
No matter if I use apt or apt-get and use autoremove my packages get purged. And when ever I install or remove a package; no longer needed packages get purged too.
nobody
  • 5,792
