How to make sh script and run it when physical poweroff button is pressed? How to remove standard handler with user confirmation for this button?
Asked
Active
Viewed 1,042 times
To remove standard handler with user confirmation for poweroff button:
- Install
dconfeditor:sudo apt install -y dconf-cli dconf-editor - Run
dconf - Set option
/org/gnome/settings-daemon/plugins/power/power-button-actiontonothing. - To check its value in console:
gsettings list-recursively org.gnome.settings-daemon.plugins.power | grep power-button-action - Configuration for this setting will be stored in user home directory.
To set up physical poweroff button handler:
Create sh script:
sudo touch /etc/acpi/poweroff.shsudo chmod +x /etc/acpi/poweroff.shsudo vim /etc/acpi/poweroff.sh- Put to it the following content:
#!/bin/bash
LOG_FILE='/var/log/poweroff.log'
#touch $LOG_FILE && chmod 0666 $LOG_FILE
touch $LOG_FILE && chmod a=rw $LOG_FILE
echo "$(date '+%Y.%m.%d %H:%M:%S.%3N'): poweroff button pressed, event: $1" >> $LOG_FILE
sudo systemctl poweroff
For example, the following commands can be used for corresponding actions:
sudo systemctl poweroffsudo systemctl suspendsudo systemctl hibernatesudo systemctl reboot
Create poweroff physical button event handler:
sudo touch /etc/acpi/events/powersudo vim /etc/acpi/events/power- Put to it the following content:
event=button/power LNXPWRBN
action=/etc/acpi/poweroff.sh "%e"
Apply changes:
sudo /etc/init.d/acpid restart
When the button is pressed new line will be added to the log file
sudo less /var/log/poweroff.log
2022.02.24 02:14:55.322: poweroff button pressed, event: button/power PBTN 00000080 00000000
2022.02.24 02:14:55.327: poweroff button pressed, event: button/power LNXPWRBN:00 00000080 00000014
Related link: Disable shutdown confirmation for physical "Power off" button in the dash (Ubuntu 20.04)
Anton Samokat
- 1,145
