I am complete beginner not much knowledge about Linux it would nice if anyone would help i am trying to fix it for long. This is my first post if there are any mistakes please forgive me.Sorry for such a long post and Thank You.
System Information
uname -a
Linux 5.13.0-40-generic #45~20.04.1-Ubuntu SMP Mon Apr 4 09:38:31 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
i don't know will it matter or not but my laptop uses uefi firmware.
neofetch
.-/+oossssoo+/-. samarth@samarth-HP-Laptop-15s-dr1xxx
`:+ssssssssssssssssss+:` ------------------------------------
-+ssssssssssssssssssyyssss+- OS: Ubuntu 20.04.4 LTS x86_64
.ossssssssssssssssssdMMMNysssso. Host: HP Laptop 15s-dr1xxx
/ssssssssssshdmmNNmmyNMMMMhssssss/ Kernel: 5.13.0-40-generic
+ssssssssshmydMMMMMMMNddddyssssssss+ Uptime: 1 hour, 23 mins
/sssssssshNMMMyhhyyyyhmNMMMNhssssssss/ Packages: 2397 (dpkg), 9 (snap)
.ssssssssdMMMNhsssssssssshNMMMdssssssss. Shell: bash 5.0.17
+sssshhhyNMMNyssssssssssssyNMMMysssssss+ Resolution: 1920x1080
ossyNMMMNyMMhsssssssssssssshmmmhssssssso DE: GNOME
ossyNMMMNyMMhsssssssssssssshmmmhssssssso WM: Mutter
+sssshhhyNMMNyssssssssssssyNMMMysssssss+ WM Theme: Adwaita
.ssssssssdMMMNhsssssssssshNMMMdssssssss. Theme: Yaru [GTK2/3]
/sssssssshNMMMyhhyyyyhdNMMMNhssssssss/ Icons: LoginIcons [GTK2/3]
+sssssssssdmydMMMMMMMMddddyssssssss+ Terminal: gnome-terminal
/ssssssssssshdmNNNNmyNMMMMhssssss/ CPU: Intel i5-10210U (8) @ 4.200GHz
.ossssssssssssssssssdMMMNysssso. GPU: Intel UHD Graphics
-+sssssssssssssssssyyyssss+- GPU: NVIDIA GeForce MX130
`:+ssssssssssssssssss+:` Memory: 2499MiB / 7754MiB
.-/+oossssoo+/-.
Network Device Details
sudo lshw -C network
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:02:00.0
logical name: eno1
version: 15
serial: 84:2a:fd:cd:34:45
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.17.0-051700-generic firmware=rtl8168h-2_0.0.2 02/26/15 latency=0 link=no multicast=yes port=twisted pair
resources: irq:16 ioport:4000(size=256) memory:b4304000-b4304fff memory:b4300000-b4303fff
*-network
description: Wireless interface
product: RTL8821CE 802.11ac PCIe Wireless Network Adapter
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlo1
version: 00
serial: 28:cd:c4:cc:8a:a3
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=rtw_8821ce driverversion=5.17.0-051700-generic firmware=N/A ip=192.168.0.104 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:141 ioport:3000(size=256) memory:b4200000-b420ffff
I have tried the following :-
- I have changed the powersave mode like this : -
cat /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
[connection]
wifi.powersave = 2
- Tried by reading forums but after this disconnecting get reduced , but speed is still slow.
sudo sed -i 's/GRUB_CMDLINE_LINUX_DEFAULT="/&usbcore.autosuspend=-1 /' /etc/default/grub
sudo update-grub
sudo systemctl reboot
Edited
3.sudo ip link set devName mtu 1492 solved the connection breaking issue for me.My default mtu is 1500 and mtu in router config is 1480 is it not a problem? But Network is still sometime slow.
Errors i found after 3rd are :-
journalctl -u NetworkManager
sup-iface[0x563452621110,wlo1]: connection disconnected (reason -4)
reason -4 means NM_DEVICE_STATE_REASON_CONFIG_FAILED now what would be the fix? and some errors on bootup
ifupdown: interfaces file /etc/network/interfaces doesn't exist
Error: failed to open /run/network/ifstate
