I've tried the procedures from:
but they don't work on Ubuntu 22.04, presumably because of the update to cgroups v2:
sudo cgcreate -a $USER:$USER -g memory:myGroup -t $USER:$USER
sudo cgset -r memory.max=500M myGroup
sudo cgset -r memory.swap.max=0 myGroup
cgexec -g memory:myGroup id
fails with:
cgroup change of group failed
It works if I run with sudo
sudo cgexec -g memory:myGroup id
but then the command runs as root, and I want it to run as the current user instead.
I read the Linux Kernel documentation and find the following (emphasis mine):
cgroup.procs
A read-write new-line separated values file which exists on all cgroups.
A PID can be written to migrate the process associated with the PID to the cgroup. The writer should match all of the following conditions.
  • It must have write access to the “cgroup.procs” file.
  • It must have write access to the “cgroup.procs” file of the common ancestor of the source and destination cgroups.
In this scenario, the common ancestor is /. So I make cgroup.procs of the root group writable:
sudo chmod o+w /sys/fs/cgroup/cgroup.procs
And now I can use cgexec as any non-root user. Not knowing if there is any security implication though.
To resolve it you need to boot your host system into CGroupV1 mode by modifying your kernel’s boot arguments to include: systemd.unified_cgroup_hierarchy=false
sudo nano /etc/default/grub
GRUB_CMDLINE_LINUX="cgroup_enable=memory swapaccount=1 systemd.unified_cgroup_hierarchy=false"
sudo update-grub sudo reboot
Pilot6
  • 92,041
renbuar
  • 41
I used to run a few resource-intensive tools with cgexec in cgroups v1. I'm not so sure this is supported in cgroups v2; at least I couldn't get it to work.
After too much time spent looking into it this is how I managed to get things going for me in Ubuntu 22.04 + cgroups v2.
1. Create a cgroup europe and (in my case) tweak permissions
$ cd /sys/fs/cgroup/
$ sudo mkdir europe create
$ ls -ld europe drwxr-x--- 2 root root 0 out 28 22:50 europe $ sudo chmod a+rx europe $ ls -ld europe drwxr-xr-x 2 root root 0 out 28 22:50 europe
Without changing permissions two things happen to me: can't cat stuff inside group without sudo, and systemd-cgtop --depth 1 returns Failed to refresh: Permission denied.
2. Limit CPU to 3 cores and RAM to 16G
I had multiple controllers available (cgroup.controllers), but the only ones being passed down the subtree were memory and pids so I added the missing cpu controller.
$ cat cgroup.controllers                       // all available
cpuset cpu io memory hugetlb pids rdma misc
$ cat cgroup.subtree_control                   // for subgroups
memory pids
$ sudo bash -c 'echo '+cpu' > cgroup.subtree_control'
$ cat cgroup.subtree_control                   // now includes CPU
cpu memory pids
$ cat europe/cgroup.controllers // can confirm in subgrp cpu memory pids
Now limit CPU and RAM:
$ cat europe/memory.max
max
$ cat europe/cpu.max
max 100000
$ echo '16G' | sudo tee europe/memory.max 16G $ echo '300000 100000' | sudo tee europe/cpu.max 300000 100000
$ cat europe/memory.max 17179869184 $ cat europe/cpu.max 300000 100000
3. Run some stuff
We can add PIDs to to europe/cgroup.procs that will then be executing in group europe.
Instead of starting a process and then adding its PID what I do is add the PID of a terminal window. Then everything run in that shell will be executed in the group.
Open another terminal:
$ cat /sys/fs/cgroup/europe/cgroup.procs
$ echo $$ | sudo tee /sys/fs/cgroup/europe/cgroup.procs 25982
$ cat europe/cgroup.procs 25982 26104 $ cat europe/cgroup.procs 25982 26105 $ cat europe/cgroup.procs 25982 26106
The first PID is the one referring to the terminal (matches echo $$ in bash) and the second PID is the command cat that's why everytime I ran the command the second PID was different.
4. Remove group when not needed
$ sudo rmdir /sys/fs/cgroup/europe
If there are still processes in europe/cgroup.procs we get an error. In this example close the terminal that was added to the group in the previous step.
Daniel C
  • 4,170
You can combine cgexec with su like this:
sudo cgexec -g memory:myGroup -- su -c 'exec id' $USER
or simply with -s:
sudo cgexec -g memory:myGroup -- su -s /usr/bin/id $USER
But the latter will rewrite $SHELL variable as the program itself.
nggit
  • 111
