System Information:
- Ubuntu 22.04
I just upgraded my Ubuntu to 22.04 a few days ago. A few months back I had uninstalled all snap related packages, including snapd because I had read on some online sources that snap packages may lead to a system slowdown. Moreover, they went against the spirit of open source. So enthusiastically I removed them. Thereafter, I had to reinstall the required packages, including Firefox, using apt. No issue in that.
After the upgrade, whenever I run
sudo apt update && sudo apt upgrade
I get the following output:
The following packages have been kept back:
firefox libomp-dev
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
I searched a bit online, and found that installing the said packages can resolve this issue.This method resolved the problem with libomp-dev, but not firefox. When I ran:
sudo apt install firefox
I got:
firefox : PreDepends: snapd but it is not installable
I thought that if it is showing that my packages are broken, then
sudo apt --fix-broken install
might help but to no avail.
So does this mean that I can no longer update my Firefox without reinstalling Snap or snapd?
