The following command was used to upgrade Ubuntu 20.04 to version 22.04:
sudo apt update && sudo apt upgrade && sudo apt dist-upgrade && sudo apt-get autoremove && sudo apt install update-manager-core && sudo do-release-upgrade -d
Unfortunately, I get the following error:
Checking for a new Ubuntu release
Failed to connect to https://changelogs.ubuntu.com/meta-release-development. Check your Internet connection or proxy settings
Upgrades to the development release are only
available from the latest supported release.
cipricus
  • 4,066
  • 47
  • 106
Use the commands individually:
sudo apt update
sudo update-manager -d
I had issues when downloading packages using a nearby server so try it with the main server.
andrew.46
  • 39,359
manoj
  • 41
I had the same problem when upgrading from Ubuntu 20.04 to 22.04 behind a proxy server like apt-cacher or apt-cacher-ng (or behind a corporate firewall), and also for an upgrade from Ubuntu 18.04 to 20.04.
I could fix this problem as follows:
As the error message states, the OS-upgrader do-release-upgrade cannot receive the file meta-release-development through https:
The solution is to use http instead of https for the transmission via proxy. This can be configured by tiny changes in the config file /etc/update-manager/meta-release:
sudo editor /etc/update-manager/meta-release
     # replace every "https" with "http"
sudo apt update
neutrino
  • 109
This message can occur if your proxy server (eg: apt-cacher-ng) doesn't support HTTPS - to work around this add changelogs.ubuntu.com to the PassThroughPattern directive in its configuration file and restart.
