12
Possible Duplicate:
How can I check if a package is installed (no superuser privileges)
I want a shell script method to test/report if a package is installed. I don't need details, only a yes/no.
I've come up with this method. Is there a more direct way?
is_installed=0
test_installed=( `apt-cache policy domy-ce | grep Installed: ` )
[ ! "${test_installed[1]}" == "(none)" ] && is_installed=1
tahoar
  • 265
You could use the output of dpkg -s <packagename> or dpkg-query -l <packagename>
in your script for the purpose.
Courtesy:https://stackoverflow.com/questions/1298066/check-if-a-package-is-installed-and-then-install-it-if-its-not
e.g.
#!/bin/sh
for P; do
    dpkg -s "$P" >/dev/null 2>&1 && {
        echo "$P is installed."
        echo "$P is not installed."
done
Usage: script.sh package1 package2 .... packageN
Courtesy:https://stackoverflow.com/a/10594734/749232
saji89
  • 12,187
