I am on Lubuntu 20.04, and the brightness controls in the settings and in brightness-controller are not working.
From Ubuntu 20.04 brightness adjust not working, I tried using brightness controller and the following error message came up:
xrandr: Gamma size is 0.
Traceback (most recent call last):
File "/usr/share/brightness-controller/init.py", line 277, in change_value_pbr
Executor.execute_command(cmd_value)
File "/usr/share/brightness-controller/util/executor.py", line 23, in execute_command
subprocess.check_output(string_cmd, shell=True)
File "/usr/lib/python3.8/subprocess.py", line 415, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "/usr/lib/python3.8/subprocess.py", line 516, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command 'xrandr --output default --brightness 0.45000000000000023 --gamma 1.0000000000000007:1.0000000000000007:1.0000000000000007' returned non-zero exit status 1.
I am on a Lenovo Legion 5i with Nvidia graphics.
