Today I received my GPD Pocket 3. It came preinstalled with Windows 11. The device looks great. I Installed Kubuntu 22.04 in dual boot (It is the first time, I have a dual boot device since winXP, but this form factor often has compatibility issues with linux, so I kept Windows as a backup).
Wifi is not working (yet), and this is where I would appreciate your help.
sudo lshw -C network
*-network
vendor: Intel Corporation
product: Wi-Fi 6 AX210/AX211/AX411 160MHz
physical id: 0
bus info: pci@0000:ae:00.0
version: 1a
width: 64 bits
description: Network controller
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list
configuration: driver=iwlwifi latency=0
resources: irq:18 memory:88400000-88403fff
lsmod | grep iwlwifi
iwlwifi 446464 1 iwlmvm
cfg80211 962560 3 iwlmvm,iwlwifi,mac80211
sudo iwconfig
lo no wireless extensions.
enp175s0 no wireless extensions.
The device does not show up in rfkill. Wifi does work in Windows 11, after installing the driver from here.
Running
sudo mv /usr/lib/firmware/iwlwifi-ty-a0-gf-a0.pnvm /usr/lib/firmware/iwlwifi-ty-a0-gf-a0.bak
as suggested in this answer, does not change anything. I would prefer not to change the kernel.
