I am trying to install mariadb-server on ubuntu 22.04 LTS but I am getting an dependency error message related to galera-4 & libssl. How to fix this issue ?
Reading package lists... Done
Building dependency tree... Done
Some packages could not be installed. This may mean that you have requested an
impossible situation or if you are using the unstable distribution that some required
packages have not yet been created or been moved out of Incoming.
The following packages have unmet dependencies: galera-4 : Depends: libssl1.1 (>= 1.1.1) but it is not installable E: Unable to correct problems, you have held broken packages.
abhijit
  • 183
Ubuntu 22.04 ships with libssl-3.0.2 which does not satisfy MariaDB's dependency requirements. That said, you can download the required library from the Ubuntu servers and install it manually.
Here's how:
  1. Open Terminal (or SSH into the machine if it's a server)
  2. Download the library:
    wget http://archive.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1f-1ubuntu2_amd64.deb
  3. Install the package:
    sudo dpkg -i libssl1.1_1.1.1f-1ubuntu2_amd64.deb
  4. Get on with your day
From this point, you will be able to install MariaDB without problems. Future updates to MariaDB will likely resolve this dependency issue by using the newer libssl3.x libraries.
matigo
  • 24,752
  • 50
  • 79
In my case, the issue happened because I'd followed a guide for adding the MariaDB repository, but the repo added was for a different OS.
My issue was fixed by using the MariaDB repo setup script, then installing:
curl -LsS https://r.mariadb.com/downloads/mariadb_repo_setup | sudo bash -s -- \
  --mariadb-server-version="mariadb-10.11" --os-type="ubuntu" --os-version="jammy"
sudo apt install mariadb-server mariadb-client -y
After I did that, the install didn't even need libssl1.1 or libreadline5.
mbomb007
  • 133
