so against common sense I've been putting off upgrading my system for a while, some things started to not work as intended recently(I assume because repos are no longer updated, or officially supported among other things), so I decided it was time to upgrade.
Since groovy is EOL, a direct upgrade to jammy is not available through the usual tool, so I followed the instructions here: https://help.ubuntu.com/community/EOLUpgrades, and ended up downloading the upgrader tool for hirsute, which seems to be the only one that works for groovy, and then I'd upgrade from it to further versions. But for some reason the tool always freezes here (">setting new software channels"), and then sends me this message (telling me to check my network) Which doesn't help much, since I clearly do have network.
I tried then to install hirsute from a bootable USB, but an option to upgrade isn't available, I would like not to completely lose my setup to start fresh, if possible. This is my setup, I have 20.10 installed on a 250GB nvme, and a 500GB sda also with a 20.10 system installed, but I basically just use it as a slave
  • OS: Ubuntu 20.10 x86_64
  • Kernel: 5.8.0-63-generic
  • Shell: bash 5.0.17
  • DE: GNOME 3.38.3
  • CPU: AMD Ryzen 5 3600XT (12) @ 3.800
  • GPU: NVIDIA GeForce GTX 1660
  • Memory: 2016MiB / 15993MiB
Thanks in advance for anyone taking the time to read this, if you could help it'd be greatly appreciated. Please let me know what other info I could provide
