Recently I upgrade my Ubuntu from 20.04 to 22.04. I was using Php7.4 in Ubuntu 20.04 with the Apache server. After upgrading to Ubuntu 22.04, the Php Upgrades to 8.1 automatically. After that, I install Php7.4 also in my system. I can switch PHP version by using this command:
sudo update-alternatives --config php
If I use terminal I can see different PHP versions using php -v. But I am unable to use Php7.4 in apache. I am trying to install using this command:
sudo apt-get install libapache2-mod-php7.4
But it's giving me the following error:
Reading package lists... Done
Building dependency tree... Done
The following packages have unmet dependencies: libapache2-mod-php7.4 : Depends: php8.1-common (= 8.1.2-1ubuntu2) but 8.1.5-1+ubuntu22.04.1+deb.sury.org+1.1 is to be installed E: Unable to correct problems, you have held broken packages.
Again if I try to activate Php7.4 in apache using this command:
sudo a2enmod php7.4
I am getting this error:
ERROR: Module php7.4 does not exist!
Now how can I use Php7.4 in my Apache? Note, that Apache was installed in Ubuntu 20.04.
guiverc
  • 33,561
