I tried to upgrade my Ubuntu from 21.10 to 22.04 with:
sudo do-release-upgrade -c
do-release-upgrade
but I always get an error:
Hit http://sk.archive.ubuntu.com/ubuntu jammy InRelease
Hit http://sk.archive.ubuntu.com/ubuntu jammy-updates InRelease
Hit https://deb.nodesource.com/node_14.x hirsute InRelease
Hit http://sk.archive.ubuntu.com/ubuntu jammy-backports InRelease
Hit http://security.ubuntu.com/ubuntu jammy-security InRelease
Ign https://packagecloud.io/ookla/speedtest-cli/ubuntu impish InRelease
Err https://packagecloud.io/ookla/speedtest-cli/ubuntu impish Release
  404  Not Found [IP: 50.18.207.89 443]
Fetched 0 B in 0s (0 B/s)
  404  Not Found [IP: 184.72.30.82 443]
Error during update
A problem occurred during the update. This is usually some sort of network problem, please check your network connection and retry.
W:Updating from such a repository can't be done securely, and is therefore disabled by default., W:See apt-secure(8) manpage for repository creation and user configuration details., E:The repository 'https://packagecloud.io/ookla/speedtest-cli/ubuntu impish Release' does not have a Release file.
I tried to remove speedtest-cli, remove snap of speedtest, but nothing helped. Any idea what could I do?
You should comment out the unofficial repositories before upgrading. This can normally be done in 2 ways:
  1. Commenting out the relevant line from /etc/apt/sources.list
  2. Renaming the relevant files inside the directory /etc/apt/sources.list.d
When you have performed the upgrade, check your old repos/files, and update them accordingly to the latest version. After that you can uncomment and/or rename the files back to activate the repositories.
For solution 1:
Find the lines containing https://deb.nodesource.com/node_14.x hirsute and https://packagecloud.io/ookla/speedtest-cli/ubuntu impish and put a # in front of the line.
For solution 2:
Find the files inside /etc/apt/sources.list.d that contains the above repositories. Rename those files, so they don't end with a .list extension (for instance, rename them to filename.list.old).
Artur Meinild
  • 31,035
First we'll find the file that's causing your errors...
cd /etc/apt
grep -i packagecloud.io sources.list
You may get no "hits" with the grep command if sources.list doesn't contain it. That's ok.
Then we look elsewhere...
cd sources.list.d
grep -i packagecloud.io *.list
This should provide you with the filename(s) that we're looking for.
Now we edit the found file(s) with...
sudo -H gedit found_filename.list
It should only contain one or two lines. Place a "#" (no quotes) at the front of each line, save the file.
Optional extra points:
grep -i deb.nodesource.com *.list
Change hirsute to impish, save the file.
sudo apt update
Should run cleanly without the errors that you previously had.
If you wish to keep speedtest-cli, use this command, taken from here...
curl -s https://packagecloud.io/install/repositories/ookla/speedtest-cli/script.deb.sh | sudo bash
Then install/reinstall speedtest-cli or speedtest if you wish.
Then you can do your upgrade.
heynnema
  • 73,649
