Ubuntu 20.04.4 LTS
I was trying to run Software Updater but got the following errors:
libpython3.7: Depends: libpython3.7-stdlib (= 3.7.13-1+focal3) but it is not installed
              Depends: zlib1g (>= 1:1.2.0) but 1:1.2.11.dfsg-2ubuntu1.3 is installed
libpython3.7-dev: Depends: libpython3.7-stdlib (= 3.7.13-1+focal3) but it is not installed
                  Depends: libpython3.7 (= 3.7.13-1+focal3) but 3.7.13-1+focal3 is installed
python3.7: Depends: python3.7-minimal (= 3.7.13-1+focal3) but 3.7.13-1+focal3 is installed
I tried the following methods but none of them worked.
sudo apt --fix-broken install
sudo apt upgrade
sudo apt-get purge python3.7
sudo apt-get autoremove && sudo apt-get autoclean
sudo apt-get install python3.7*
Xin
  • 161
I had the same issue while trying to upgrade Ansible from the ppa.
I removed python using the advice in this issue: The following packages have unmet dependencies python 3.7
 sudo apt --fix-missing purge $(dpkg -l | grep 'python3\.7' | awk '{print $2}')
Then ran apt upgrade and the issue appears to be resolved.
shift
  • 143
