I just upgraded to Ubuntu 22.04 and I installed Gitkraken using snap. When opening Gitkraken via the terminal, a windows pops up, but closes immediatly without printing any messages in the terminal. I tried installing gitkraken via the software shop, and using the tar.gz, but the same issue occured. Does anybody else have the same problem? If so how did you fix it?
Kind regards
To expand on the previous answer, here is a step by step instruction set to get open SSL 1.1.1 libs on Ubuntu 22.04:
Get build tools:
sudo apt-get install build-essential checkinstall zlib1g-dev -y
Make working dir:
mkdir openssl-v1.1.1 && cd openssl-v1.1.1
Get Open SSL 1.1.1 latest version:
wget https://www.openssl.org/source/openssl-1.1.1o.tar.gz
tar -xvzf openssl-1.1.1o.tar.gz
cd openssl-1.1.1o
Configure build:
chmod +x ./config
./config
Build it (j = ncores)
make -j 4
Test it:
make test
If everything works, move the libs to your local lib.
sudo mv libssl.so.1.1 /usr/lib/x86_64-linux-gnu/
sudo mv libcrypto.so.1.1 /usr/lib/x86_64-linux-gnu/
Now GitKraken from the terminal should launch:
gitkraken
The snap is always a few versions behind the .deb, and you only have to build open SSL once on 24.04, then all subsequent .deb installs will work as normal.
in my case was necessary run : sudo kill -9 {PID} and open the GitkKraken again.
I believe it was running what I had installed manually before, it was necessary to kill the process in hand and open the version installed by snap.
When I run gitkraken from the terminal, it logs 'build/Debug/nodegit.node' is not found.
It turns out the nodegit.node requires openssl v1. Specifically, it needs two files, libcrypto.so.1.1 and libssl.so.1.1.
By default ubuntu 22.04 use openssl v3 and there is not openssl v1 in the apt repository. So I compiled the latest openssl v1 manually and configured a custom install prefix just in case it may cause conflicts in the future, then symbolic link these two files to /lib/x86_64-linux-gnu.
openssl v1 github release page
