I'm using pavilion with ryzen5 5625u. I already tried this answer and disabled secure boot according another answer. I also ran sudo systemctl restart network-manager but it says it failed to restart . I also went to software and update for additional drivers, but it has no additional drivers to install.
it says no wifi adapter
output of cat /etc/modprobe.d/iwlwifi.conf
output of cat command
this is the output of ip a # check if you can see wireless card
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
3: usb0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 1000
    link/ether 42:be:a8:da:f2:40 brd ff:ff:ff:ff:ff:ff
    inet 192.168.42.182/24 brd 192.168.42.255 scope global dynamic noprefixroute usb0
       valid_lft 3593sec preferred_lft 3593sec
    inet6 fe80::2ace:eaf0:c3ba:8cf9/64 scope link noprefixroute
and output of lspci -knn | grep Network -A3 # This shows card name and driver, if in use.
libkmod: ERROR ../libkmod/libkmod-config.c:712 kmod_config_parse: /etc/modprobe.d/iwlwifi.conf line 8: ignoring bad line starting with '“options'
01:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. Device [10ec:b852]
    DeviceName: Realtek Wireless LAN + BT
    Subsystem: Hewlett-Packard Company Device [103c:88e3]
02:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller 980 [144d:a809]
Edit 1 output of my ifconfig is
$ifconfig
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 488  bytes 60829 (60.8 KB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 488  bytes 60829 (60.8 KB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
wlx200db01052d8: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.1.12 netmask 255.255.255.0 broadcast 192.168.1.255 inet6 fe80::45dc:7ce4:395e:7bf1 prefixlen 64 scopeid 0x20<link> ether 20:0d:b0:10:52:d8 txqueuelen 1000 (Ethernet) RX packets 12242 bytes 14993668 (14.9 MB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 9344 bytes 1371773 (1.3 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
and output of ifup and ifdown is
ifup: no interface(s) specified
ifup: Use --help for help
ayu_j
I'm not sure if this is any help, however I am using 22.04.1 Server. I am using a built in wi-fi card and I am connected. However in the GUI it does not show me using wi-fi according to the icon and the drop down. This is what my interfaces look like:
$ ifconfig
docker0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 172.17.0.1  netmask 255.255.0.0  broadcast 172.17.255.255
        ether 02:42:b1:0a:f1:5e  txqueuelen 0  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
enp3s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether 38:60:77:83:9c:d0 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 199 bytes 18849 (18.8 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 199 bytes 18849 (18.8 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
wlp2s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.1.27 netmask 255.255.255.0 broadcast 192.168.1.255 inet6 fe80::76de:2bff:fe3c:bab3 prefixlen 64 scopeid 0x20<link> ether 74:de:2b:3c:ba:b3 txqueuelen 1000 (Ethernet) RX packets 1532 bytes 814657 (814.6 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 957 bytes 167662 (167.6 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
interface wlp2s0 is my wifi card. Maybe use $ ifdown and $ ifup to see if that works for your situation. (sudo apt install net-tools if you don't have them already)
Hope this helps.
anonymous2
  • 4,325
Clay B
