So I've been trying to update to Ubuntu 22.04 development release but certain errors are coming. Whenever I try to update the following error comes ->
abc@ubuntu:~$ update-manager -d
Checking for a new Ubuntu release
authenticate 'jammy.tar.gz' against 'jammy.tar.gz.gpg'
extracting 'jammy.tar.gz'
No candidate ver:  chromium
No candidate ver:  microsoft-edge-stable
Traceback (most recent call last):
  File "/tmp/ubuntu-release-upgrader-6ylluso8/jammy", line 8, in <module>
    sys.exit(main())
  File "/tmp/ubuntu-release-upgrader-6ylluso8/DistUpgrade/DistUpgradeMain.py", line 241, in main
    if app.run():
  File "/tmp/ubuntu-release-upgrader-6ylluso8/DistUpgrade/DistUpgradeController.py", line 2038, in run
    return self.fullUpgrade()
  File "/tmp/ubuntu-release-upgrader-6ylluso8/DistUpgrade/DistUpgradeController.py", line 1881, in fullUpgrade
    if not self.updateSourcesList():
  File "/tmp/ubuntu-release-upgrader-6ylluso8/DistUpgrade/DistUpgradeController.py", line 784, in updateSourcesList
    self.sources = SourcesList(matcherPath=self.datadir)
  File "/usr/lib/python3/dist-packages/aptsources/sourceslist.py", line 273, in __init__
    self.matcher = SourceEntryMatcher(matcherPath)
  File "/usr/lib/python3/dist-packages/aptsources/sourceslist.py", line 470, in __init__
    dist = DistInfo(base_dir=matcherPath)
  File "/usr/lib/python3/dist-packages/aptsources/distinfo.py", line 184, in __init__
    with open(dist_fname) as dist_file:
FileNotFoundError: [Errno 2] No such file or directory: '/tmp/ubuntu-release-upgrader-6ylluso8/Ubuntu.info'
Error in sys.excepthook:
  File "/usr/lib/python3/dist-packages/problem_report.py", line 477, in add_to_existing
    self.write(f)
  File "/usr/lib/python3/dist-packages/problem_report.py", line 430, in write
    block = f.read(1048576)
  File "/usr/lib/python3.8/codecs.py", line 322, in decode
    (result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0x8b in position 1: invalid start byte
Original exception was: Traceback (most recent call last): File "/tmp/ubuntu-release-upgrader-6ylluso8/jammy", line 8, in <module> sys.exit(main()) File "/tmp/ubuntu-release-upgrader-6ylluso8/DistUpgrade/DistUpgradeMain.py", line 241, in main if app.run(): File "/tmp/ubuntu-release-upgrader-6ylluso8/DistUpgrade/DistUpgradeController.py", line 2038, in run return self.fullUpgrade() File "/tmp/ubuntu-release-upgrader-6ylluso8/DistUpgrade/DistUpgradeController.py", line 1881, in fullUpgrade if not self.updateSourcesList(): File "/tmp/ubuntu-release-upgrader-6ylluso8/DistUpgrade/DistUpgradeController.py", line 784, in updateSourcesList self.sources = SourcesList(matcherPath=self.datadir) File "/usr/lib/python3/dist-packages/aptsources/sourceslist.py", line 273, in init self.matcher = SourceEntryMatcher(matcherPath) File "/usr/lib/python3/dist-packages/aptsources/sourceslist.py", line 470, in init dist = DistInfo(base_dir=matcherPath) File "/usr/lib/python3/dist-packages/aptsources/distinfo.py", line 184, in init with open(dist_fname) as dist_file: FileNotFoundError: [Errno 2] No such file or directory: '/tmp/ubuntu-release-upgrader-6ylluso8/Ubuntu.info'
Is there any solution to this? I guess a file named Ubuntu.info is missing.
EDIT: I was asked to disable 3rd party repos by @vanadium, but the results remained unchanged.
abc@ubuntu:~$ sudo do-release-upgrade -d
No candidate ver:  pipewire-audio-client-libraries
No candidate ver:  pipewire-bin
No candidate ver:  pipewire-media-session
No candidate ver:  pipewire-pulse
  File "/tmp/ubuntu-release-upgrader-son1yxme/jammy", line 8, in <module>
    sys.exit(main())
  File "/tmp/ubuntu-release-upgrader-son1yxme/DistUpgrade/DistUpgradeMain.py", line 241, in main
    if app.run():
  File "/tmp/ubuntu-release-upgrader-son1yxme/DistUpgrade/DistUpgradeController.py", line 2038, in run
  File "/tmp/ubuntu-release-upgrader-son1yxme/DistUpgrade/DistUpgradeController.py", line 1881, in fullUpgrade
  File "/tmp/ubuntu-release-upgrader-son1yxme/DistUpgrade/DistUpgradeController.py", line 784, in updateSourcesList
FileNotFoundError: [Errno 2] No such file or directory: '/tmp/ubuntu-release-upgrader-son1yxme/Ubuntu.info'
    self.write(f)
Original exception was: Traceback (most recent call last): File "/tmp/ubuntu-release-upgrader-son1yxme/jammy", line 8, in <module> sys.exit(main()) File "/tmp/ubuntu-release-upgrader-son1yxme/DistUpgrade/DistUpgradeMain.py", line 241, in main if app.run(): File "/tmp/ubuntu-release-upgrader-son1yxme/DistUpgrade/DistUpgradeController.py", line 2038, in run return self.fullUpgrade() File "/tmp/ubuntu-release-upgrader-son1yxme/DistUpgrade/DistUpgradeController.py", line 1881, in fullUpgrade if not self.updateSourcesList(): File "/tmp/ubuntu-release-upgrader-son1yxme/DistUpgrade/DistUpgradeController.py", line 784, in updateSourcesList self.sources = SourcesList(matcherPath=self.datadir) File "/usr/lib/python3/dist-packages/aptsources/sourceslist.py", line 273, in init self.matcher = SourceEntryMatcher(matcherPath) File "/usr/lib/python3/dist-packages/aptsources/sourceslist.py", line 470, in init dist = DistInfo(base_dir=matcherPath) File "/usr/lib/python3/dist-packages/aptsources/distinfo.py", line 184, in init with open(dist_fname) as dist_file: FileNotFoundError: [Errno 2] No such file or directory: '/tmp/ubuntu-release-upgrader-son1yxme/Ubuntu.info'
Just ran into this while doing a do-release-upgrade manually. The gui was failing before this. The workaround answer from here by MarianD is what solved it for me. You need to create the Ubuntu.info file in the /tmp/ubuntu-release-upgrader-*/ folder using touch.
for example: touch /tmp/ubuntu-release-upgrader-93aizvle/Ubuntu.info
This can be tricky since it makes a new folder every time you run do-distribution-upgrade and it can fail before you have a chance to type in the touch command for the newly created folder. Exciting! Took me 4 tries. Remember to capitalize the 'U'.
I have a strong feeling adding a PopOS repo to my system is to blame. I did it to get a non-snap version of Chromium but all hell broke loose as a result. I tried to undo the damage but two years later I still run across some scars. I see a reference to Pop.info in many of the answers to this problem.
Rishon_JR
  • 1,028
Just was surfing through internet and found the solution to this problem, and my Ubuntu 20.04 was successfully upgraded to 22.04. The solution can be found here.
Instead of a file called “Pop.info”(as given in the answer) make a file called “Ubuntu.info”
