When trying to open a program that requires Qt6, it gives error while loading shared libraries: libQt6Network.so.6: cannot open shared object file: No such file or directory. I tried installing Qt6 by going to the Qt website -> Downloads for open source users -> Download the Qt Online Installer -> Qt Online Installer for Linux (64-bit), then in the installer itself I selected "Qt 6.2 for desktop development". After it'd finished installing I restarted and tried to open the program again, and it still gave the same error. I'd also seen sudo apt install qt6-base-dev be suggested so I tried that, but that just gives the error Unable to locate package qt6-base-dev, so now I'm not sure what else I could try.
Asked
Active
Viewed 8.9k times
19
Foxes
- 293
- 1
- 2
- 5
23
libqt6network6 is indeed part of the qt6-base-dev meta-package and you can install it like so:
However, unfortunately, this meta-package is not available for Ubuntu 21.10. It is currently available only for Ubuntu 22.04
Raffa
- 34,963
You might try to use Owen Kirby's backport of Qt6:
sudo add-apt-repository ppa:okirby/qt6-backports
sudo apt update
sudo apt install qt6-base-dev [...]
Just like @Raffa, I also strongly recommend the update to Ubuntu 22.04, and Owen Kirby's backports are perhaps not the most up to date (6.2.2 at the time of writing; it's a LTS version; the most recent version of Qt 6 is 6.3.1), but it should get you going
Gwyneth Llewelyn
- 191
