I installed Ubuntu 22.04 on my laptop Asus N551JM. After installation, Bluetooth adapter is not available. How I can solve this problem?
sudo dmesg |grep -i bluetooth
[ 3.772671] Bluetooth: Core ver 2.22
[ 3.772699] NET: Registered PF_BLUETOOTH protocol family
[ 3.772701] Bluetooth: HCI device and connection manager initialized
[ 3.772705] Bluetooth: HCI socket layer initialized
[ 3.772707] Bluetooth: L2CAP socket layer initialized
[ 3.772711] Bluetooth: SCO socket layer initialized
[ 3.935429] Bluetooth: Patch file not found ar3k/AthrBT_0x11020000.dfu
[ 3.935472] Bluetooth: Loading patch file failed
[ 7.652405] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 7.652409] Bluetooth: BNEP filters: protocol multicast
[ 7.652412] Bluetooth: BNEP socket layer initialized
inxi -Fxxxz
System:
Kernel: 5.15.0-25-generic x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: GNOME 42.0 tk: GTK 3.24.33 wm: gnome-shell dm: GDM3 42.0
Distro: Ubuntu 22.04 (Jammy Jellyfish)
Machine:
Type: Laptop System: ASUSTeK product: N551JM v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: N551JM v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: N551JM.204 date: 10/06/2014
Battery:
ID-1: BAT0 charge: 53.4 Wh (100.0%) condition: 53.4/56.2 Wh (95.1%)
volts: 10.8 min: 10.8 model: ASUSTeK N551-52 type: Li-ion serial: N/A
status: Not charging
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K270
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
CPU:
Info: dual core model: Intel Core i5-4200H bits: 64 type: MT MCP
smt: enabled arch: Haswell rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 1297 high: 1298 min/max: 800/3400 cores: 1: 1298
2: 1297 3: 1297 4: 1296 bogomips: 22348
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
Device-2: NVIDIA GM107M [GeForce GTX 860M] vendor: ASUSTeK driver: nvidia
v: 510.60.02 pcie: speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1392 class-ID: 0302
Device-3: IMC Networks USB2.0 UVC HD Webcam type: USB driver: uvcvideo
bus-ID: 3-7:5 chip-ID: 13d3:5188 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: gnome-shell driver: X:
loaded: modesetting,nvidia unloaded: fbdev,nouveau,vesa gpu: i915
display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 98 s-size: 499x280mm (19.6x11.0")
s-diag: 572mm (22.5")
Monitor-1: eDP-1 model: Samsung res: 1920x1080 hz: 60 dpi: 142
size: 344x194mm (13.5x7.6") diag: 395mm (15.5") modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 4600 (HSW GT2)
v: 4.6 Mesa 22.0.1 compat-v: 3.1 direct render: Yes
Audio:
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Sound Server-1: ALSA v: k5.15.0-25-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
Device-1: Qualcomm Atheros AR9462 Wireless Network Adapter
vendor: AzureWave driver: ath9k v: kernel pcie: speed: 2.5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 168c:0034 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 05:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0f1 state: down mac: <filter>
Bluetooth:
Device-1: IMC Networks Atheros AR3012 Bluetooth type: USB driver: N/A
bus-ID: 3-5:4 chip-ID: 13d3:3474 class-ID: e001
Drives:
Local Storage: total: 465.76 GiB used: 138.94 GiB (29.8%)
ID-1: /dev/sda vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 023 scheme: GPT
Partition:
ID-1: / size: 56.02 GiB used: 7.8 GiB (13.9%) fs: ext4 dev: /dev/sda8
ID-2: /boot/efi size: 95 MiB used: 30.2 MiB (31.8%) fs: vfat
dev: /dev/sda2
ID-3: /home size: 42.68 GiB used: 591.3 MiB (1.4%) fs: ext4
dev: /dev/sda9
Swap:
ID-1: swap-1 type: partition size: 11.44 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda7
Sensors:
System Temperatures: cpu: 49.0 C mobo: N/A
Fan Speeds (RPM): cpu: 1800
Info:
Processes: 248 Uptime: 27m wakeups: 3 Memory: 11.58 GiB
used: 2.88 GiB (24.8%) Init: systemd v: 249 runlevel: 5 Compilers: gcc: N/A
Packages: 1692 apt: 1683 snap: 9 Shell: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.13
