No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.6 LTS
Release:        18.04
Codename:       bionic
Really struggling with finding a solution to my issue. I was trying to install mongoDB on wsl and received an error. I followed the instructions from the error and ran sudo apt --fix-broken-install but I also ran into trouble and received an error. As a result, I followed the advice from this post Broken APT on WSL 18.04 and ran:
sudo rm -rf /etc/apt/apt.conf.d/20snapd.conf
which seemed to fix it and moved me along. I ran sudo apt --fix-broken-install again and everything seemed to be working well until I received this error:
Preparing to unpack .../12-python3-lib2to3_3.8.10-0ubuntu1~20.04_all.deb ...
Unpacking python3-lib2to3 (3.8.10-0ubuntu1~20.04) over (3.6.9-1~18.04) ...
dpkg: error processing archive /tmp/apt-dpkg-install-WWYJAm/12-python3-lib2to3_3.8.10-0ubuntu1~20.04_all.deb (--unpack):
 trying to overwrite '/usr/lib/python3.9/lib2to3/Grammar.txt', which is also in package python3.9-lib2to3 3.9.11-1+bionic1
Preparing to unpack .../13-python3-distutils_3.8.10-0ubuntu1~20.04_all.deb ...
Unpacking python3-distutils (3.8.10-0ubuntu1~20.04) over (3.6.9-1~18.04) ...
dpkg: error processing archive /tmp/apt-dpkg-install-WWYJAm/13-python3-distutils_3.8.10-0ubuntu1~20.04_all.deb (--unpack):
 trying to overwrite '/usr/lib/python3.9/distutils/README', which is also in package python3.9-distutils 3.9.11-1+bionic1
Preparing to unpack .../14-libgirepository-1.0-1_1.64.1-1~ubuntu20.04.1_amd64.deb ...
Unpacking libgirepository-1.0-1:amd64 (1.64.1-1~ubuntu20.04.1) over (1.56.1-1) ...
Preparing to unpack .../15-libglib2.0-0_2.64.6-1~ubuntu20.04.4_amd64.deb ...
Unpacking libglib2.0-0:amd64 (2.64.6-1~ubuntu20.04.4) over (2.56.4-0ubuntu0.18.04.9) ...
Preparing to unpack .../16-libnewt0.52_0.52.21-4ubuntu2_amd64.deb ...
Unpacking libnewt0.52:amd64 (0.52.21-4ubuntu2) over (0.52.20-1ubuntu1) ...
Preparing to unpack .../17-libstdc++6_10.3.0-1ubuntu1~20.04_amd64.deb ...
Unpacking libstdc++6:amd64 (10.3.0-1ubuntu1~20.04) over (8.4.0-1ubuntu1~18.04) ...
I then tried to run sudo apt --fix-broken-install again to see what would happen and received:
sudo apt --fix-broken install
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
  dh-python libpython3.6-dev python3.6 python3.6-dev python3.6-minimal
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  apt apt-utils libapt-pkg6.0 libgnutls30 libhogweed5 libnettle7 libp11-kit0 libpython3-stdlib libtasn1-6 python3-distutils python3-lib2to3
Suggested packages:
  apt-doc aptitude | synaptic | wajig gnutls-bin
The following NEW packages will be installed:
  libapt-pkg6.0 libhogweed5 libnettle7
The following packages will be upgraded:
  apt apt-utils libgnutls30 libp11-kit0 libpython3-stdlib libtasn1-6 python3-distutils python3-lib2to3
8 upgraded, 3 newly installed, 0 to remove and 665 not upgraded.
31 not fully installed or removed.
Need to get 0 B/3,879 kB of archives.
After this operation, 3,932 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up libffi7:amd64 (3.3-4) ...
(Reading database ... 60412 files and directories currently installed.)
Preparing to unpack .../libpython3-stdlib_3.8.2-0ubuntu2_amd64.deb ...
Unpacking libpython3-stdlib:amd64 (3.8.2-0ubuntu2) over (3.6.7-1~18.04) ...
Setting up libstdc++6:amd64 (10.3.0-1ubuntu1~20.04) ...
Selecting previously unselected package libapt-pkg6.0:amd64.
Preparing to unpack .../libapt-pkg6.0_2.0.6_amd64.deb ...
Unpacking libapt-pkg6.0:amd64 (2.0.6) ...
Setting up libapt-pkg6.0:amd64 (2.0.6) ...
(Reading database ... 60461 files and directories currently installed.)
Preparing to unpack .../python3-lib2to3_3.8.10-0ubuntu1~20.04_all.deb ...
dpkg: error processing archive /var/cache/apt/archives/python3-lib2to3_3.8.10-0ubuntu1~20.04_all.deb (--unpack):
Preparing to unpack .../python3-distutils_3.8.10-0ubuntu1~20.04_all.deb ...
dpkg: error processing archive /var/cache/apt/archives/python3-distutils_3.8.10-0ubuntu1~20.04_all.deb (--unpack):
Selecting previously unselected package libnettle7:amd64.
Preparing to unpack .../libnettle7_3.5.1+really3.5.1-2ubuntu0.2_amd64.deb ...
Unpacking libnettle7:amd64 (3.5.1+really3.5.1-2ubuntu0.2) ...
I've tried a few approaches which I found from this post https://github.com/deadsnakes/issues/issues/98 , which consisted of running:
sudo dpkg --install --force all /var/cache/apt/archives/python3-lib2to3_3.6.9-1~18.04_all.deb
sudo dpkg --install --force all /var/cache/apt/archives/python3-distutils_3.6.9-1~18.04_all.deb
and
sudo apt purge python3.8-distutils python3.8-lib2to3
But neither of them worked and I'm still getting the same error. Something else confuses me. If I'm running ubuntu 18.04, why are packages from 20.04 being unpacked? I recently tried upgrading to 20.04 but I had a lot of issues so I decided to hold off. Could that have something to do with it?
Apologies if I sound foolish, but this is all very new to me. My bootcamp set me up with a wsl dev environment and I'm pretty lost when it comes to solving any issues with it. It brings me such anxiety and I'm scared to run any commands, tbh. If anyone can help, that'd be fantastic.
Nmath
  • 12,664
Nunchuk
  • 101
