12
I just installed CrashPlan for Linux. After installing, I deleted the installer folder and files, and the icon sitting on my desktop (after dragging it to the launcher). I rebooted, now the launcher icon is gone and I can't find any way to start the CrashPlan Desktop application.
How do I get the launcher back so I can start the program?
Tom Brossman
  • 13,297
Download CrashPlan for Linux, saving the .tgz archive on your Desktop.
Double-click on the file to open it with Archive Manager, then extract it to the Desktop. You should have a folder now named 'CrashPlan-install' on your Desktop.
Open the Terminal and navigate to the folder containing the installer. Run the install script, using the default choices:
cd ~/Desktop/CrashPlan-install
sudo ./install.sh
After it finishes, you need to do three things.
  1. Edit the .desktop file (to make it compatible with the Unity Launcher).
  2. Copy it to .local/share/applications.
  3. Drag it from .local/share/applications onto the launcher.
Edit the .desktop file first:
gedit ~/Desktop/CrashPlan-install/scripts/CrashPlan.desktop
Add the line 'StartupWMClass=CrashPlan' at the end, so it looks like this:
[Desktop Entry]
Version=1.0
Encoding=UTF-8
Name=CrashPlan
Categories=;
Comment=CrashPlan Desktop
Comment[en_CA]=CrashPlan Desktop
Exec=/usr/local/bin/CrashPlanDesktop
Icon=/usr/local/crashplan/skin/icon_app_128x128.png
Hidden=false
Terminal=false
Type=Application
GenericName[en_CA]=
Save, and exit the text editor. Now copy the file:
cp ~/Desktop/CrashPlan-install/scripts/CrashPlan.desktop ~/.local/share/applications
The last part is the easiest. Open your /home folder in Nautilus, and press Ctrl+H to show hidden files.
Now just go to .local/share/applications, grab the icon with your mouse, and drag it to the Unity Launcher.
Credit to @451F 's answer here, which I based this on.
Tom Brossman
  • 13,297
from the terminal enter:
right-click on the launcher in the dock and click "Lock to Launcher"
