I aliased sudo to please with a space:
$ alias please='sudo '
$ please ll
I have tried this in Fish, but it doesn't work:
$ please ll
sudo: ll: command not found
NotTheDr01ds
  • 22,082
Octopus
  • 63
The problem here isn't nested aliases. That in itself will work, although (as @muru points out in the comments) somewhat differently than Bash. For instance:
$ alias a ls
$ alias b type
$ b a
a is a function with definition
# Defined via `source`
function a --wraps=ls --description 'alias a ls'
  ls $argv;
end
The problem with sudo in a Fish alias is twofold:
  • First, an alias is defined for your user, but when you sudo, you aren't "your user" any more. The fish configuration inside sudo is that of the root user. Unfortunately, the elegant Bash solution of appending a "space" doesn't work for Fish.
  • The Bash "trailing space" workaround of expanding the second alias before passing it to the first, via alias please='sudo ' isn't available in Fish. For instance, in the preceding example, in Bash you could use alias b='type ' to force expansion of a to ls and run the type command on the result rather than the alias.
    This is, IMHO, definitely one area where Bash has a (much) cleaner solution than Fish.
There are a few possible workarounds for Fish, but I think they are all rather "hacky", even my own.
First, as I mention in [this Stack Overflow answer], you can define your sudo alias as follows:
function please --wraps=sudo --description 'alias please sudo'
    if functions -q -- "$argv[1]"
        set cmdline (
            for arg in $argv
                printf "\"%s\" " $arg
            end
        set -x function_src (string join "\n" (string escape --style=var (functions "$argv[1]")))
        set argv fish -c 'string unescape --style=var (string split "\n" $function_src) | source; '$cmdline
        command sudo -E $argv
    else
        command sudo $argv
    end
end
It would probably take me a bit to remember exactly how I arrived at that, which is why I left a commented version with the explanation here.
While you might consider defining the alias in the root user's Fish config, note that sudo only runs external commands, so it still won't run aliases this way, unless you ask a new fish process to run it. E.g.:
$ sudo -s
$ alias -s ll "ls -l"
funcsave: wrote /root/.config/fish/functions/ll.fish
$ exit # back to normal user
$ sudo fish -c "ll"
$ sudo ll
$ sudo fish -c "ll -n /"
total 1436
lrwxrwxrwx   1 0 0       7 Apr 23  2020 bin -> usr/bin
drwxr-xr-x   2 0 0    4096 Apr 23  2020 boot
NotTheDr01ds
  • 22,082
