24
My wifi connection keeps disconnecting frequently (say once in a couple of minutes) sometimes it gets back and sometimes I need to activate and deactivate aeroplane mode. I tried to change my network provider to make sure it is this laptop problem and not the internet I use. The same happened with ADSL connection, android hotspot, and TD LTE modem. Really annoying. Some info: output of lspci -knn | grep Net -A2:
02:00.0 Network controller [0280]: Qualcomm Atheros AR9485 Wireless Network Adapter [168c:0032] (rev 01)
    Subsystem: Lite-On Communications Inc AR9485 Wireless Network Adapter [11ad:6628]
    Kernel driver in use: ath9k
    Kernel modules: ath9k
and out put of grep wlan /var/log/kern.log:
Apr 17 21:26:24 mb-X202E kernel: [   18.970719] ath9k 0000:02:00.0 wlp2s0: renamed from wlan0
Apr 17 23:49:29 mb-X202E kernel: [   19.312256] ath9k 0000:02:00.0 wlp2s0: renamed from wlan0
Apr 18 00:30:25 mb-X202E kernel: [   18.915112] ath9k 0000:02:00.0 wlp2s0: renamed from wlan0
Apr 18 12:26:07 mb-X202E kernel: [   21.278385] ath9k 0000:02:00.0 wlp2s0: renamed from wlan0
Apr 18 22:21:55 mb-X202E kernel: [   19.425881] ath9k 0000:02:00.0 wlp2s0: renamed from wlan0
Apr 21 19:56:26 mb-X202E kernel: [   18.985724] ath9k 0000:02:00.0 wlp2s0: renamed from wlan0
Ubuntu 22.04
Gnome 42
Asus X202E
9 Answers9
16
Try:
sudo nano /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
And change wifi.powersave to 2
I tried most of the answers above, some of them worked but the problem started again after a couple of hours. Finally I installed a fresh Ubuntu and get rid of the disconnection syndrome but the same thing started to happen the day before yesterday.
At last my searches led to a bug with the 5.15 kernel and I found that there are many people facing the same problem with 5.15 and 5.16 kernels. I just updated to the latest kernel (5.17.7) and it has solved the problem for two days now.
I tried this solution to update to the latest kernel
Had the same bug (same wifi chipset, but in an old Toshiba) after installing Ubuntu 22.04.
Appears to be a bug in the 5.15 kernel, and solved by installing the 5.17 kernel.
I did the following :
wget -c https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.17.5/amd64/linux-headers-5.17.5-051705_5.17.5-051705.202204271406_all.deb
wget -c https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.17.5/amd64/linux-headers-5.17.5-051705-generic_5.17.5-051705.202204271406_amd64.deb
wget -c https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.17.5/amd64/linux-image-unsigned-5.17.5-051705-generic_5.17.5-051705.202204271406_amd64.deb
wget -c https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.17.5/amd64/linux-modules-5.17.5-051705-generic_5.17.5-051705.202204271406_amd64.deb
sudo dpkg -i linux*.deb
Then I rebooted, and wifi works fine now.
Pilot6
  • 92,041
Mark
  • 69
i had an old machine with (linux ubuntu lts 22.04) internel wifi hardware named intel corporation centrino wireless-n 1000 condor peak. i had tried all methods, installing differnt kernels, but nothing worked me. after rigorous research i found this thread https://ubuntuforums.org/showthread.php?t=2274336. Steps to follow
  1. Go to wifi settings
  2. Go to ipv6 tab
  3. Disable
My wifi is much much faster, Full speed and No slow browsing reply and give a thumbs up, if this works for you
Similar behavior, wifi keeps disconnecting and malfunction
my hardware : laptop Asus N751JK Network controller: Qualcomm Atheros AR9462 Wireless Network Adapter (rev 01) Subsystem: AzureWave AR9462 Wireless Network Adapter
I was runing Ubuntu 20.10, 21.04 up to Ubuntu 21.10 with Kernel 5.13.0 without any problem. I migrated to Ubuntu 22.04 which installs Kernel 5.15 then the problems started. I upgraded and tested unsuccessfully the following Kernels : 5.15.28, 5.15.36, 5.16.14, 5.16.20, 5.17.4, 5.17.5
I disabled the power save as explained without improvement in any of the Kernels tested. Also the "intel_iommu=off" mentioned at https://groups.google.com/g/linux.debian.kernel/c/RFpPIp0cncA/m/v9ELDxLICgAJ Bug#994590 didn't help.
I downgraded and currently running without any problem using the Kernel 5.13.19-051319-generic.
There is no problem in my airpoint (router) nor my internet access, I have other different computers and devices working correctly on wifi. In addition the N751JK works correctly when using the Ethernet adapter for the physical cable.
more on this https://bugzilla.kernel.org/show_bug.cgi?id=215703
https://bugzilla.kernel.org/show_bug.cgi?id=215698
https://bugs.archlinux.org/task/74187
So I tried all of the solutions listed here, however, what worked me was upgrading the Kernel to 5.17.14-051714-generic. It's been working for about 30 minutes. I will update this thread is the issue persists. Fingers crossed!
My specs: Clean install Ubuntu 22.04.1 with Intel Wireless PCI-e card.
Good Luck!
0xjoe
  • 31
after installing the 5.17 kernel there may be a problem with updating the program core and the appearance of the message system:
error: bad shim signature.
error: you need to load kernel first.
press any key to continue...
it can be fixed by disabling secure boot from BIOS
Using the solution mentioned in @chili555 comment, I tried disabling Power saving and it worked sofar (at least for the recent 20 minutes which is a record):
sudo sed -i 's/3/2/' /etc/NetworkManager/conf.d/*
P.S: By the way, when I have set power mode to balanced in power settings, why there must be a power saving setting like that enabled?
Probably not a solution, but helped me.
  • Being on Ubuntu 22.04/DELL Precision 5540/Wireless-AC 9260
  • after multiple upgrades and downgrades
  • trying kernels5.0.0-23, 5.13.19-051319, 5.15.0-47, 5.19.5-051905
i became desperate and started writing a re-connecting script, following How to connect and disconnect to a network manually in terminal?
But as soon as i tried the first command to connect from terminal:
$ nmcli device wifi connect MY_SSID password "MY_PW"
The connection became stable and not interrupting any more!
radistao
  • 197
