18
I have a fresh install of Ubuntu 22.04 on a Ryzen 5 CPU machine, I install Chrome from https://www.google.co.uk/chrome/ choosing the 64bit .deb package, and the install works with no errors seen.
However running Chrome it never displays anything, and give an error:
kevin@home:~$ google-chrome libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
[23127:23127:0422/093510.765043:ERROR:sandbox_linux.cc(377)] InitializeSandbox() called with multiple threads in process gpu-process.
I tried rm -rf ~/.config/google-chrome, I also tried google-chrome --disable-gpu --no-sandbox, but both don't work.
This is the Chrome version:
kevin@home:~$ google-chrome --version
Google Chrome 100.0.4896.127
That was the way out sudo google-chrome --disable-gpu --no-sandbox:
kevin@home:~$ sudo google-chrome --disable-gpu --no-sandbox
[sudo] password for kevin:
[29946:29973:0422/095302.474445:ERROR:bus.cc(397)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[29946:29973:0422/095302.474504:ERROR:bus.cc(397)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
Authorization required, but no authorization protocol specified
[29981:29981:0422/095302.480831:ERROR:angle_platform_impl.cc(44)] DisplayVkXcb.cpp:59 (initialize): xcb_connect() failed, error 1
[29981:29981:0422/095302.480902:ERROR:angle_platform_impl.cc(44)] Display.cpp:966 (initialize): ANGLE Display::initialize error 12289: Not initialized.
[29981:29981:0422/095302.480949:ERROR:gl_surface_egl.cc(808)] EGL Driver message (Critical) eglInitialize: Not initialized.
[29981:29981:0422/095302.480973:ERROR:gl_surface_egl.cc(1430)] eglInitialize SwANGLE failed with error EGL_NOT_INITIALIZED
[29981:29981:0422/095302.481006:ERROR:gl_ozone_egl.cc(20)] GLSurfaceEGL::InitializeOneOff failed.
[29981:29981:0422/095302.481880:ERROR:viz_main_impl.cc(188)] Exiting GPU process due to errors during initialization
[29946:29973:0422/095302.483125:ERROR:bus.cc(397)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[29946:29973:0422/095302.483146:ERROR:bus.cc(397)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[30017:30017:0422/095302.509279:ERROR:angle_platform_impl.cc(44)] DisplayVkXcb.cpp:59 (initialize): xcb_connect() failed, error 1
[30017:30017:0422/095302.509350:ERROR:angle_platform_impl.cc(44)] Display.cpp:966 (initialize): ANGLE Display::initialize error 12289: Not initialized.
[30017:30017:0422/095302.509401:ERROR:gl_surface_egl.cc(808)] EGL Driver message (Critical) eglInitialize: Not initialized.
[30017:30017:0422/095302.509432:ERROR:gl_surface_egl.cc(1430)] eglInitialize SwANGLE failed with error EGL_NOT_INITIALIZED
[30017:30017:0422/095302.509467:ERROR:gl_ozone_egl.cc(20)] GLSurfaceEGL::InitializeOneOff failed.
[30017:30017:0422/095302.510423:ERROR:viz_main_impl.cc(188)] Exiting GPU process due to errors during initialization
[30043:30043:0422/095302.523272:ERROR:angle_platform_impl.cc(44)] DisplayVkXcb.cpp:59 (initialize): xcb_connect() failed, error 1
[30043:30043:0422/095302.523368:ERROR:angle_platform_impl.cc(44)] Display.cpp:966 (initialize): ANGLE Display::initialize error 12289: Not initialized.
[30043:30043:0422/095302.523423:ERROR:gl_surface_egl.cc(808)] EGL Driver message (Critical) eglInitialize: Not initialized.
[30043:30043:0422/095302.523468:ERROR:gl_surface_egl.cc(1430)] eglInitialize SwANGLE failed with error EGL_NOT_INITIALIZED
[30043:30043:0422/095302.523512:ERROR:gl_ozone_egl.cc(20)] GLSurfaceEGL::InitializeOneOff failed.
[30043:30043:0422/095302.524597:ERROR:viz_main_impl.cc(188)] Exiting GPU process due to errors during initialization
[30094:30094:0422/095302.533872:ERROR:gpu_init.cc(446)] Passthrough is not supported, GL is disabled, ANGLE is
[30094:30107:0422/095302.535111:ERROR:x11_software_bitmap_presenter.cc(141)] XGetWindowAttributes failed for window 10485763
Running as root I get a bit further, but it hangs with a small (and empty) "Welcome to Google Chrome", box and lots of errors, any ideas?
Kevin W
  • 323
9 Answers9
10
Just remove the broken configuation by running :
rm ~/.config/google-chrome/ -rf
liedji
  • 201
Experienced the same google-chrome libva error on an Intel when downloading both Chrome and Opera (chromium based) for Ubuntu 22.04 LTS.
Resolved the issue for both browsers by restarting after completing the download (entering reboot into the terminal).
Although, I feel silly suggesting to turn your computer off and on again.
Ra31513
  • 89
I found this article: https://notes.enovision.net/linux/google-chrome-not-starting-in-ubuntu and it helped.
Basically, what I did:
sudo vim /usr/share/applications/google-chrome.desktop
Change:
Exec=/usr/bin/google-chrome-stable %U
To:
Exec=/usr/bin/google-chrome-stable --password-store=basic %U
Also removing local config files seems to help:
Same overall problem but in my case it was a file permissions obstruction:
$ sudo apt install wget
Reading package lists... Done
Building dependency tree... Done
wget is already the newest version (1.21.2-2ubuntu1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
$ wget https://dl.google.com/linux/direct/google-chrome-stable_current_amd64.deb
--2023-03-26 14:35:18--  https://dl.google.com/linux/direct/google-chrome-stable_current_amd64.deb
Resolving dl.google.com (dl.google.com)... 172.253.116.91, 172.253.116.93, 172.253.116.190, ...
Connecting to dl.google.com (dl.google.com)|172.253.116.91|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 93863468 (90M) [application/x-debian-package]
Saving to: ‘google-chrome-stable_current_amd64.deb’
google-chrome-stabl 100%[===================>] 89.51M 4.97MB/s in 19s
2023-03-26 14:35:38 (4.66 MB/s) - ‘google-chrome-stable_current_amd64.deb’ saved [93863468/93863468]
$ sudo dpkg -i google-chrome-stable_current_amd64.deb Selecting previously unselected package google-chrome-stable. (Reading database ... 338595 files and directories currently installed.) Preparing to unpack google-chrome-stable_current_amd64.deb ... Unpacking google-chrome-stable (111.0.5563.110-1) ... Setting up google-chrome-stable (111.0.5563.110-1) ... update-alternatives: using /usr/bin/google-chrome-stable to provide /usr/bin/x-www-browser (x-www-browser) in auto mode update-alternatives: using /usr/bin/google-chrome-stable to provide /usr/bin/gnome-www-browser (gnome-www-browser) in auto mode update-alternatives: using /usr/bin/google-chrome-stable to provide /usr/bin/google-chrome (google-chrome) in auto mode Processing triggers for mailcap (3.70+nmu1ubuntu1) ... Processing triggers for gnome-menus (3.36.0-1ubuntu3) ... Processing triggers for desktop-file-utils (0.26-1ubuntu3) ... Processing triggers for bamfdaemon (0.5.6+22.04.20220217-0ubuntu1) ... Rebuilding /usr/share/applications/bamf-2.index... Processing triggers for man-db (2.10.2-1) ... Processing triggers for menu (2.1.47ubuntu4) ... $ google-chrome /usr/bin/google-chrome: line 8: /usr/bin/readlink: Permission denied /usr/bin/google-chrome: line 10: /usr/bin/dirname: Permission denied /usr/bin/google-chrome: line 24: /usr/bin/mkdir: Permission denied
The 3 folders:
/usr/bin/readlink /usr/bin/dirname /usr/bin/mkdir
are readable and executable by all users but only writable by root.
Is there code in /usr/bin/google-chrome that is trying to alter the code in these 3 directories ?
It is really strange why Chrome has always seemed to have a problem with Ubuntu . . .
I think we should take this clanger of a hint here.
Let's all stick to Chromium.
Trunk
  • 729
Ubuntu 22.04 has issues with Wayland.
Solution: (worked for me)
  • Use X11
  • Try removing any conflicting applications, in my case culprit was Citrix Receiver.
Remove with follwing command:
sudo apt remove icaclient && sudo apt purge icaclient
I hope it works for you as well.
https://askubuntu.com/a/1464995/1690831
There is a recent confirmed bug here that appears to have the same error message that I'm encountering, and seems to be similar to what was reported in this thread:
https://bugs.launchpad.net/ubuntu/+source/linux-meta-nvidia-5.19/+bug/2017980
I think this means Ubuntu and nvidia are working on it.
I've had Chrome stopped working and the issue was that I changed my machine name and Chrome started to complain that the profile is in use on other user or other machine. Fixed by deleting chrome profile.
(Ubuntu 24.04.1 LTS)
Mesqalito
  • 101
Deleting all the ~/.config/google-chrome directory as other answers suggest works, but you'll lose all profile data, such as passwords, bookmarks, (previous) opened tabs, etc.
You can try to erase only the SingletonLock file since it's most likely causing the issue. This file ensures that only one instance of the browser is running at a time.
This way you'll not lose any profile data or (previous) opened tabs:
killall chrome
killall chromium
rm ~/.config/google-chrome/SingletonLock
-1
My sister also ran into this problem on Ubuntu 22.04 due to not updating the system regularly.
I solved it simply as follows:
Press the windows key, type "terminal" and press enter
Enter these commands:
cd .config
rm google-chrome/ -rf
cd
sudo reboot
When the system reboots, Google Chrome will work normally.
To avoid these kinds of issues, I recommend regularly opening a terminal as above, and running this command to update the system and remove old things:
sudo apt update && sudo apt upgrade -y && sudo dist-upgrade -y && sudo snap refresh && sudo apt autoremove -y
Zanna
  • 72,312
